Home | Bosch | 24 in. SHU66C05 Stainless Steel Built-in Dis... | Loose dirt and a lot of ...
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Problem for Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Loose dirt and a lot of watter won't drain when cycle completed
By ander63 on Apr 10, 2009
The dishwasher appears to operate properly except that there is a lot of water left in the bottom that is filled with loose dirt. This dirt then gets attached to the new load of dishes. The dishes don't come out clean.
Solution #1
posted on Apr 11, 2009
Not Rated)
wheelshot
Rank: Guru
Rating: 92%, 68 votes
One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it not to drain. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine especially in a Bosch. This should take care of your problem.
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHU66C05
Questions and Unsolved Problems for Bosch 24 in. SHU66C05
Do you recommend Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher?
Answer
Answer
I found that by initially disconnecting the pipes and cleaning them out (without the usual... (More)
Answer
our bosch dishwasher had some water on the floor . I think it's coming from the bottom seal of the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C05...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
