SOURCE: Eaton Arc Fault Breaker type BRAF tripped.
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
SOURCE: Have three 20 amp Eaton
If you disconnect the load wires on the breaker and it will not reset, the breaker has a fatal flaw.
IF the breaker ONLY fails to reset with the load wires connected EITHER there is a wrong connection like servicing a shared neutral 3 wire cable from the breaker, or there is an electrical fault OR there is interference from a source that couples radio-like noise onto the wires to this.
