Question about Samsung Digimax 800K Digital Camera
Chargung problem how can i charge my carera ot battery
  • kaushal jha Sep 09, 2007
    the battery will empty in 20 minuite how can i recgahre my batterey
After I charge my PSP ot last for about 10 mins but I charge it up fully
You need a new battery! Only charge your psp untill full. Then disconnect the charger! If you leave it on charge constant you damage the battery! Also battery's dont last forever and a psp is not in its prime. Good luck!
Nov 15, 2014 | Sony PSP (Piano Black)
My alcatel OT-906 phone is not opening
Hello My Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 26, 2012 | MOBILESW Alcatel OT-906 2.8" Resistive...
Driving down the highway turn lights on battery power drains (check guages light comes on) turn lights off battery continues ot charge and hold a charge. . generator? Alternator?
first of all, check voltage at battery car off should read at least 12.5 to 13 volts. now start car. at battery it should read at least 14 volts, if lower then 14 volts check alternator.
Dec 17, 2010 | 1998 Dodge Ram 1500 4WD
Got wet; dried. ot new battery but still does not hold charge.
Best bet here, take it to a camera shop, if it got wet you have water damage, with that said would be the reason why it doest ot hold charge. The cause is the unit is not charging the battery or has shorted out inside so it does not hold charge.
point in case here there is nothing a email expert can do but suggest what you to do next going forward.
thanks and please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 14, 2010 | Kodak EasyShare V603 Digital Camera
Zen mp4 was not used for one month and now the zen is not getting charged and just blinking
as with all zen products i.e. mp3/mp4 players the chargung port is cheaply made and breaks after about 6 months there's not much you can really do except a buy a new one or b contact the manufactureer and see if yu can send it in for a repair
Apr 25, 2009 | Creative Labs Zen V MP3 Player
My alarm in my porsche 911 carera s plate goes can you help
if you are talking about the trigger in your plate that sensor probably is shot and needs to be replaced by the dealer only. porche is a picky car when it comes to its repairs i have worked as a master porche tech and they are very sensitive.
Jan 25, 2009 | 1988-1989 911 Carrera Relay Alarm
Put new duracell batteries in my s85 camera turns on but when you go to take a photo it turns off?
ok did u have old batteries in the carera the first time? if u did i can only think that one of the batteries haved had a leak and u have battry acid in it. thats all i can think of but if this isent the problem contact your service provider and/or samsung and ask them what you can do to fix this
hope it helps
Jul 18, 2008 | Samsung Cameras
Cell phone charging
u have to try it once connect ur phone thu a cable and selet phone mode or pcsuit to see if its chargung ur cell or not
Feb 07, 2008 | Cell Phones
Samsung Digimax 800K Digital Camera Logo
61 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
