Question about Miele 24 in. G638 Plus Free-standing Dishwasher
Dishwasher does not complete cycle
I have a Miele DW.G638. The DW seems to get almost to the end of it"s cycle the stops. The Inlet/drain indicator flashes.When you open the cabinet and look inside there is some water in the bottom.However when you restart the water is drained away.Any thoughts as to why it does not finish it"s programmed cycle.It seems to stop before drying time.
  • psaints Sep 09, 2007
    Thanks dovi for your help.After having read other posts it seems to me that similar problems are common place on these machines. That is Miele DW'S.My machine has completed one programmed cycle since. Hopefully the problem has cleared .I did blow down the drain hose before I originally posted.Thanks again. Psaints
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
These days everything is a computer, check all lines(water in) & (drain line) then there is a water sensor at the bottom of the unit, if the dtain pump keeps running; there is a leak & trouble shoot to find it. If all checks out it's the control board in the door. It will usually be the 1st thing to go bad.
25 yrs appliance repair
Posted on Jan 28, 2013
  • 641 Answers
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 09, 2007
SOURCE:
Hi, We have a G638 plus and have it connected to the cold water tap. When we press start, it fills the machine with water and once the machine has been filled, the program doesn't start and after 2-3...
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Miele 24 in. G638 Plus Free-standing...
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
Does anyone know why a Miele diswasher will start to wash fine and then stop with the inlet/drain light flashing after a few mins? I looked at the pressure stat at the bottom of motor and when i blow in it...
hi,
you may have something rapped around the impellers of the circulation pump causing low water pressure. the unit will start and stop to try to clear the blockage. if the circulation pump is really jammed the inlet/drain light will light. it could be a faulty pressure switch but they are not common to fail.
Hope this helps
May 21, 2010 | Miele 24 in. G638 Plus Free-standing...
The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Salt PC indicator light
I downloaded the manual off line and it gave me the facts I needed.
Thank you,
Markus
Sep 08, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele dishwasher
we have the same dishwasher with the exact same problem. I just pulled it about one or two feet out of its little cupboard thing and the error goes away and it works again, i think that it must extend the hose and free it up a little bit.
Dec 06, 2007 | Miele 24 in. G638 Plus Free-standing...
Inlet/Drain light keeps flashing
Kenyanjoe, I have had the same problem with a G638 . the inlet/drain light flashed 30 sec after start up, (the machine must empty on start up, this did not happen), This caused it to lock out on alarm I removed the drain hose from the S trap,removed the non return valve from the filter, check the drain pump impellar is free, then blow down the drain hose back into the dishwasher to make sure it was not blocked then found the drain pipe on the S trap under the sink was restricted causing the machine not to empty in time for the cycle to continue causing it to lockout on inlet/drain alarm. Have a go , good luck. GUNNO
Aug 14, 2007 | Miele 24 in. G693 Free-Standing Dishwasher
Miele G638 dishwasher.
Hi John I have the same problem, the manual says that it is because the water level is to low, this is checked by opening the door after the machine has stopped filling and before it starts to wash, the level should be 4mm above the main plastic filter ring, the level has two settings, these can be adjusted by pressing the start button and the On/Off button at the same time, release the start button and turn the control to economy 45,if the start light does not come on the level is set to normal, to increase level press the start button again and the light should come on, this will give you an increased filling time. it did no help me but it may help you. good luck
Jun 05, 2007 | Miele 24 in. G638 Plus Free-standing...
Miele 24 in. G638 Plus Free-standing Dishwasher Logo
753 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
