Question about Sony Cyber-shot DSC-N2 Digital Camera
Sony n2 camara problem
I got a sony n2 camara. when i try to switch it on. a black screen comes and it says to swich off and on the camara. what could be the problem?
  • 7 more comments
  • Anonymous Nov 01, 2007
    When I turn on my sony dsc-n2 the screen reads "Access", then "Turn the power off and on again." What is the fix?
  • Anonymous Nov 15, 2007
    My camera does the same thing. When I turn it on it says Turn the power off and on again.
  • srqcrab Nov 28, 2007
    Same problem can access card but the lens cover won't shut and lens won't telescope out.
  • ernestkaye Nov 29, 2007
    I have the same exact problem... can't rtn to mfg b/c i never had a receipt.. It was a gift... PLEASE HELP!!!
  • Anonymous Dec 27, 2007
    When i switch on my camera the lens is not working properly. it shuts down and then opens again and keep repeating.. also the screen appears black and beep sound keeps coming. please help
  • Anonymous Feb 12, 2008
    Quando ligo a camera no modo foto ou filmagem, aparece a palavra "acesso", depois a tela fica preta escrito "Lig.e deslig.aliment. O que devo fazer?
  • alha Mar 06, 2008
    Sometime the picture has a part of the previous picture on the bottom.
    About a 1/4 to 3/8 inch overlap.
  • Viciburrell Apr 21, 2008
    You know I have the same problem so have taken into sony service centre. The lady was not surprised and said ok a technician will contact you. Estimated cost 80 singapore dollars repair. This morning I have a call from the centre saying the whole lens needs replacing due to being dropped. I said excise me but the camera has not been dropped and as I am a photographer and it is kept in the same conditions as all my SLR cameras in dehumidifiers etc I am very surprised at the comment. He insisted that the problem was the lens mechanism and would be 410 singapore dollars to repair!! I have just started chcking around as this seesm to be a real common problem. It is interesting to note that Sony have discontinued thsi model with no replacement. It was on the market just over 1 year which might indicate THEY know there is a problem. It seems that it happens just after you have had it a year and therefore out of warranty!
  • ozzieskids Jul 07, 2008
    Had the same problem, tried all solutions suggested on this website, AND it STILL won't work! It just keeps fluttering, and it doesn't come out far enough for me to grab ahoId of it. I was told $251 to fix it. I have had the camera only year.
Thanks i tried pulling the lense gently and it works very very thanks.
Posted on Apr 28, 2008
Thank you ppcjay for the worked like a charm!
Pulled out the lens on the first go. I turned off the camera and then when I turned the power up again...disco!!
Now if only Sony would fess up to this issue. I mean without any extended warranty the best advice I could get was to buy a new camera...and I can tell you it wouldn't have been a Sony!
Posted on Feb 05, 2008
Ok guys, I was getting the same "Access" black screen on my dcsn2. I would turn it on and the lens would pop in and out I would get the black screen with the "Access" on it. What worked for me was the following:
As the lens came out i grabbed and pulled while it was fully extended
The "Access" screen disappeared and my camera was back to normal.
hope this works for u guys! :-)
Posted on Dec 28, 2007
SONY DCR200 CAMCORDER turn off when I Opend th LCD but it's working when attached with AC power Cable
More than likely the camera has an internal problem in the power supply section. There is an electronic switching circuit that switches between the battery input and the DC input coming from the AC adapter. Your camera requires professional servicing. One such place is Home Services Consumer Camcorder Sony
Nov 25, 2014 | Sony Video Cameras
2005 chevy tahoe driver power seats and passenger windows don't work
Try checking fuses first of course then n2 the swich check terminalz plugged n2 switch then if u dnt have power either a relay o switch itself . .. .
Oct 28, 2012 | 2005 Chevrolet Chevrolet Tahoe Z71
Having problems with my DSC-N2. Screen is starting to take only dark pics even with the flash and sometimes there redish lines across the screen and also comes out in the pics
It sounds like a problem with the CCD imaging sensor itself. Most likely you will want to consider replacing the camera. You do have the option to contact sony and get an estimate. You can also contact/send it to a independent camera repair company and they commonly offer free estimates.
Here is sony's contact info:
Thank you,
Jan 26, 2011 | Sony Cyber-shot DSC-N2 Digital Camera
My Sony Cybershot DSC-N2 touchscreen will not work.
if the initialize and calibration settings cannot be accessed if the touch screen is not responding, try to power reset the camera: turn cam off, remove the battery, make sure the cam is not connected to an optional ac adaptor, set mode switch to play, press and hold down the power button for a minute, let go and turn cam mode back to off, reinsert battery and turn cam on. if touch screen is still not working, unit may require service. hope this helps. thanks:)
Aug 25, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
The screen on my sony dscn-n2 is broken where can i buy new screen?
Part number of lcd for Sony DSC-N2 is as follows:
A1151474A... TP BLOCK ASSY (30STGU05) (including LCD)
Available in Sony Part Store for $192
Apr 18, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
I need to restart my camara.
I just got a fuji digital camera. I was taking pictures and it said memory full and then the lcd screen went dark gray with a green dot in the middle. I then opened the memory card and installed it. I can still take pictures and see thru the focus lens but not the lcd screen.????? pls. help
Dec 15, 2009 | Canon Cameras
Sony N2 veiwfinder problem!
Can you see Shadow images[ indicating back light failure]
or Nothing at all[ Indication main circuit board or connector problem
If you are still in warranty then send it back to seller.
You could try gently squeezing the case below the screen to see if there is a chance of a re connection.
Also check out Sony support in case there is an issue with that model
Failing that it is a repair job
Prbably nearly as expensive as simply junking it and start over
May 07, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-shot  DSC-N2 Digital Camera Logo
198 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
