Question about Cameras
Formattting again and again my SanDisk Extreme III 4.0 Gb CompactFlash Card
I have a Nikon D200, and every time I turn it on to use it, it wants me to reformat the CompactFlash Card. If I do this I will loose my pictures and I can not get it to even open on my computer.
  • vwhitney Sep 10, 2007
    Can you suggest a good file recovery program? Thanks
    Brigadier General:
  • 6,966 Answers
Hi, It may be possible that your CompactFlash Card is nearing its end. You can try formatting it after you have downloaded into your PC all the pictures. Try to use the camera's built-in formatting function. Thereafter plug it back to your PC and use a disk checking utility such as scandisk or Norton Disk Doctor. Do an intensive check including the free space. If the disk check shows any errors, then the CompactFlash Card is no longer a reliable storage media and you are better off purchasing a replacement rather than gamble that it will still work. If for some reason, even your PC can not access the card, you have to use a file recovery program to recover/download/copy the picture files and then try the disk check utility. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 09, 2007
  • Louie  Role
    Louie Role Sep 10, 2007
    I normally use GetDataBack for FAT. The demo/freeware version will allow you only a few files to recover at a time.
SOURCE:
Can't get the photos to download from Scandisk. Format issue?
if u remove the card while the cam is on then it sometimes occurs the files may get corrupted so copy all the photo to a computer then format the card then copy it again to the card then insert it to your cam all cam pics are in jpeg extension so check the extension of the pics while copying to your card.
Oct 17, 2009 | SanDisk Extreme III 4GB Secure Digital...
SanDisk Extreme Firewire Reader not recognized by Vista machine
I opened the reader mechanically by unscrewing the two screws beneath the rubber pad in the bottom. I saw that two pins were pushed out of the connector. By carefully pressing them back in again I found that after closing the unit and carefully inserting a CF card it was working again Yipee!!
Jan 05, 2009 | SanDisk Extreme FireWire 400/800...
New Nikon D90 goes into ERR after several shots. only correction is to remove the battery and replace then it resets. I have sandisk extreme III 4 gb memory so speed is not the issue. any thoughts on this?
If the camera is fairly new, the lens is more likely the problem. Try another lens. If the same happens, it's probably a shutter problem.
Jan 04, 2009 | Cameras
Not able to read contents from Memory disk
I)try this rightclick on the drive and select the option 'Explore'
Thanking you
M. Sridhar
Jan 01, 2009 | SanDisk Extreme III 2GB Secure Digital...
WHEN I INSERT CARD, CAMERA SAID CAN NOT BE USED.
the 4800 is a older model that won't support a sdhc card-go back to 2gb or smaller and problem solved-don't waste money on high speed cards for a basic point and shoot camera
Aug 30, 2008 | Nikon Coolpix 4800 Digital Camera
D300 control panel
No, it is not a malfunction, and it is perfectly normal. It is just a heads-up-display of how many pictures you have left. THere might be a way to turn it off, so consult the user manual, or go to this link.
http://www.nikonusa.com/pdf/manuals/noprint/D300_en_noprint.pdf
Feb 23, 2008 | Nikon D300 Body Only Digital Camera
Flashing Low Battery
Let me know if you have a solution...Mine just started doing the same thing
Dec 11, 2007 | Nikon D200 Digital Camera with 18-200mm...
Cameras Logo
102 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
