Question about Compaq Presario 1275 Notebook
BIOS Clock Error
I'm helping a friend out with an old Presario 1275. Right now, I get a BIOS error during boot that says the date/time settings are invalid - hit F1 to continue or F10 to fix. If I hit F1, it boots normally, but the date & time are set to 1/1/98 12:00. If I hit F10, I can set the current date & time, but the settings go away the next time it's shut down. In either case, time begins to count up from whenever it's reset, so the internal clock does run. I guessed it was a bad CMOS battery and replaced that. It still gives the same error message! I pulled the new CMOS battery out & tested the voltage, and it's right on - the new battery is good. I made sure I reinstalled it with the correct polarities. Now what?
  • jms30s Aug 01, 2008
    Hi, I can't locate the CMOS battery on the Compaq Presario 1275. Would someone please inform me where it is? Thanks!
    Hi, I can't locate where the CMOS battery is on the Compaq Presario 1275. Would someone please let me know where exactly it is? Thanks!
    Sergeant:
  • 457 Answers
Update the BIOS or CMOS it should be fine after that.
Posted on Sep 09, 2007
SOURCE:
Bios rom checksum error, boot block bios vI.0
Error BIOS ROM CHECKSUM - SYSTEM HALTED.
Cause Bad Hardware
Solution Unfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair.
If you wish to repair this issue yourself the motherbard will need to be replaced.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Apr 14, 2012 | ASUS A8N-E Motherboard
Bad check sum cmos
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
hope this helps you
Nov 18, 2011 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
I have turned on my laptop and the error message 163 - time and date not set is displayed and I cannot do anything
During the boot process you will see on the screen to press a certain key to enter setup
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time internet time tab hope hope this helps you
Apr 05, 2011 | Computers & Internet
Well i have a few problems the first is it Says that there is a disk drive 0: Fujistu MHF2043AT error, and Real time Clock error,and it can not find save to disk file, and can not boot at all. I have...
One thing at a time.
The real time clock is kept on time by a CMOS battery and if the battery goes flat, the time will be lost as will the CMOS data that tells the notebook that there is a hard drive installed.
Replace the CMOS battery first, set the time and date in the BIOS then let the BIOS detect the hard drive.
When the BIOS bit is happy, place a system disk in the DVD Drive and load a fresh OS.
Hope that helps, and have a nice Xmas.
Dec 23, 2010 | Compaq Presario 1255 Notebook
Save to disk file not found run ph disk for info
the cmos is under the aluminum of the keyboard try to remove it carefully its too easy
Jul 16, 2009 | Compaq Presario 1275 Notebook
Bios problem,system not boothing in normal mode
Try downloading the latest ChipSet for your intel board, second go into the BIOS and set your clock...
easier than that, double click on the clock at the bottom right of your screen and set it to the correct time and correct time zone, click Apply and then OK that will get rid of the checksum error.
You're doing fine, don't give up on the new drivers. You are almost there....
Hope this does it for you my friend, good luck,
please leave rating, thankyou kindly
Apr 25, 2009 | Computers & Internet
I've got a compaq presario 1245 laptop. On booting it gives me a black screen with "Error 0270 Real Time Clock Error" I can get into the Setup and boot screens (F1 & F10) but any changes (reset date/time...
hi
you will need to open your computer and look inside. if you are not sure take to a repair centre, the battery is on the motherboard, thats why you need to take really if you are going to be doing it. But i would advised to get a IT guy to do it for you. once its taken out you need to replace it with a new one.
Mar 25, 2009 | Compaq Presario 1275 Notebook
System disc error Compaq Pesario 1275
This is either an issue with the CMOS batter which may need to be changed, I have seen this error on thinkpads and one way of resolving it is to install an older BIOS, you can download a BIOS from your machine and install it using there instructions
Hope this helps
Nov 24, 2008 | Compaq Presario 1275 Notebook
Boot error accures
THE BEST SOLUTION IS TO FORMAT IT AND REINSTALL THE OPERATING SYSTEM. IF YOU DON'T KNOW HOW TO DO SO, BETTER CONTACT YOUR SYSTEM VENDOR OR IT PROFESSIONAL.
May 20, 2008 | Compaq Presario 1275 Notebook
Open Questions:
See all Compaq Presario 1275 Notebook Questions
Compaq Presario 1275 Notebook Logo
793 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
