Question about Philips Magnavox 27MS343S 27" TV
1998 27' magnavox tv/combo
There is too much picture screen (it's zoom) to fit in the tv 's picture frame
    New Friend:
  • 76 Answers
Frame width is normal means. Check aspect ratio is changed in menu options. Even width is also enlargement means there is high output from power supply section. Check and change the high voltage filter capacitor.
Posted on Sep 09, 2007
SOURCE:
How to resize picture on a magnavox mwc20t6
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Nov 26, 2014 | Philips Magnavox MWC20T6 TV
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
Nov 25, 2013 | Philips Magnavox 27MS343S 27" TV
The picture on my new 55" lcd hdtv overlaps the
Find a buttons on ur tv remote control that said like VIEWMODE,P.size or a Zoom.Push one of these buttons to find the wright picture mode to fit in ur tv picture screen frame.
Nov 22, 2010 | Vizio VF550M 55 in. LCD HDTV
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
Jul 23, 2010 | Proscan 42LA45H 42 in. LCD TV
Hi our panasonic viera has a very large picture that does not fit into the frame of the TV. Normal option under picture isn't available and zoom isn't working either is aspect
hi hust a tip hope it would work, try to adjust the aspect ratio, if not check if ther is a zoom button on the remote that can actually adjust the size of the picture but normally adjusting the aspect ratio will solve the problem. hope this would work, goodluck!!!
Jun 03, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Cannot get the full picture on screen
if you zoom it and it did not work then your problem is in the vertical circuit
May 23, 2010 | Philips Magnavox 27MS343S 27" TV
I have a 10" frame. The picture that I take with my digital camera is cropped by the frame. It seems to crop about an inch off the edges. How can I fix this. I can alter the picture if necessary.
Depends...
if it's during a slide show, then there's a slide show option "screen fit or fill".  If you are set to fill then it will cut off edges, change the setting to screen fit.
or if it is cutting off all 4 sides when displaying a single photo, you may have the zoom turned on.  Tap actions / zoom and set the zoom back to 1x.
Dec 15, 2008 | Kodak EasyShare EX1011 Digital Picture...
PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips Magnavox 27MS343S 27" TV Logo
167 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
