Question about Maytag MSD2436GR Side by Side Refrigerator
NOT ENOUGH WATER.
WATER DISPENSER BARELY SHOOTS OUT WATER. VERY SMALL AMOUNT COMES OUT. THE ICE MAKER IS MAKING A FUNNY NOISE MAKING ICE.
  • 725 Answers
Check to see if the water line is kinked or if the valve is partly closed.next check to see if you have some blockage in the line. Shut the water off, remove the filter element,if you hace one and blow air in the water dispenser. If that doesn't do it, remove the line after the shut off, and blow air in before the filter. if all is good you may have to replace the water valve solenoid. Is your ice maker making ice ? if not it is not getting water either. let me know if this helps..
Posted on Sep 09, 2007
The ice maker is making ice but when we push the dispeser from the outside it only shoots out water and no ice. What is the problem?
your dispenser will only do one or the other??... I my be wrong, but I have never seen one dispense water and ice at the same time???
Jul 11, 2017 | Refrigerators
Mr freeze ice maker only making partial cubes
Oy, ice makers! This can happen if there is low water pressure, and that can happen if the water filter needs replacement. Another explanation is evaporation which can happen after even a few days. But if they come out of the ice maker small, it's probably the filter -- if it also has a water dispenser, you might notice that water comes out slowly. If the filter doesn't fix it, the actual water feed may not be providing enough water pressure for some reason ... maybe as simple as loosening the valve on the back ... but probably not likely.
Aug 03, 2016 | Refrigerators
Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
the water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
May 28, 2010 | Hotpoint HSM25GFRSA
Icemaker in side by side fridge not making ice
Most likely the ice maker itself needs to be replaced.  Take of the cover of the ice maker and there are test points on it.  L is line voltage and should have power.  V is valve and should also have power.  Unplug the ice maker and jumper the two middle wires togather fro a second.  If water comes out then it is definately the ice maker.  If not either the valve is shot not letting water in, or the filter is clogged not allowing enough water in.  The ice maker does not have a level sensor to tell when it is full it just opens the valve for a give amount of time.  Usually 5 seconds.  Also check the where the water comes into the ice maker.  Sometimes ice builds up there stopping water flow.
Oct 25, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Water comes out dispenser when ice maker calls for water
if the ice makers calling and its comming out of the doorthe valves are wired yhe wrong way around swop the wires from one valve to another. hope this helps
Feb 12, 2008 | Refrigerators
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag MSD2436GR Side by Side Refrigerator Logo
107 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
