PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Ibm thinkpad 385xd
By jeweler on Sep 09, 2007
I picked up this old laptop at an auction and it comes on but I cannot get the windows 2000 to come up. It has an error code
Comments:
Sep 09, 2007
- It says on the first screen that it runs windows 2000, but I cannot get it to load, The error is 00301 The battery is dead, I have to run the machine with the new power cord I ourchased
Same Problem
Aug 28, 2008
-   my ibm thinpad 385xd have an error 301,and i cant change my boot sequence.pls tell me how can i change it-   Guest
May 03, 2008
-   same trouble only it refuses to boot up and i'm getting a weird color picture like its not reading right. then i get 21 301 = a not ok sign , an arrow pointing at IBM book ? how to fix-   Guest
Best Solution
posted on Sep 09, 2007
Very Helpful)
harvester3
Rank: Guru
Rating: 85%, 186 votes
Can you tell me what the error code is?
I'd be surprised if that old of a machine doesn't need a cmos battery replaced. I'm surprised it's running Win2k.
Comments:
Sep 10, 2007
- Hi,
Actually, I'm looking at a 380z right now, and it has one screw from bottom of case, which holds it in place.
I don't think that I would worry about the 301 code right yet, as thinkpads are very touchy about the keyboard when booting; in other words, if you hold a key just a bit to long during boot up, it will show the 301 error.
As for it not booting to the operating system, probably just need to re-install, or at least do a repair.
I bet since you got it in an auctioin, and its as old as it is, the os just needs some help to boot.
Good little lappy tho. If it turns out you do have a keyboard problem, I've got about a dozen new keyboards for the 38xx series and would be glad to part with one if you pay the freight.
Turn on the machine, wait till after the "press F1 to setup" leaves, then hit F8 repeatedly. Hopefully that will allow you to choose "safe mode" for boot.
If successful, let it run in safe mode for awhile, then reboot and see if it works.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on Sep 10, 2007
Helpful)
Syclar
Rank: Wiz
Rating: 81%, 51 votes
301 indicates a stuck key. Just test each in turn to see if one is immobile. The keyboard is usually held in place by screws on the bottom, which should be marked. Undo the screws and gently lever the keyboard forward. You can then check that the keyboard cable is properly inserted into its socket, or if there is any dirt stopping a key moving.
Was this helpful?
Yes
No
Solution #3
posted on Dec 30, 2008
Not Rated)
windsongb
Rank: Apprentice
Rating: 0%, 0 votes
Hi, The 385xd is a great little laptop. To change the boot sequence you need to go into the BIOS, to do that you need to hold down the shift F1 key, while the system is trying to load. You should see a blue screen with square icons. Tab over to the boot Icon.(or use the red scroll button) There should be a bird cursor, and hit the enter key, from there you can change the sequence of bootup. If you have a startup disk for win 2000, you can use that from the floppy drive after you reset the boot sequence. It will ask bring up a screen and have a list of ways to boot to the hard drive for restore. Hope this helps.
Was this helpful?
Yes
No
Solution #4
posted on Oct 16, 2008
Not Rated)
precisearts
Rank: Apprentice
Rating: 0%, 0 votes
I just woke up to a 502 error (stuck key) After checking the keyboard & disconnecting it I FINALLY got into system restore .After 2 tries 2 that I restored to a point BEFORE I installed SERIF Pages Plus and everything is fine now .(VIRUS)? ....I dont know ,but,I'll just leave that one alone for now! Maybe it's just me, but I didn't like the feeling of maybe having to restore& losing ALL my pictures Saved business cards,etc. I hope this helps.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
how loose the keyboard, some of the keys stick!!
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
Gateway M285-E, powers up, power button and wireless light turn on, but no video on screen. A... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
