Question about SanDisk Sansa e250 MP3 Player
EVERYTHING VANISHED ANY ONE PLZ HELP
Yesterday i waz listening to my songs.After some time it had auto-shut off.Then wen i opened it i found "DATABASE REFRESH FAILED".Then wen i opened for songs and videos they were empty.But the space covered is still there.Then i connected it to my computer in MPT mode then when i opened it i found no Photos,Videos and songs folder. PLZ HELP PLZ HELP.......shud i format it...
  • 1 more comment
  • 2kool Sep 09, 2007
    FORMAT IN WHICH MODE
    it wud be helpful if u guide thtrough the whole proccess of formatting
  • Anonymous Jun 25, 2008
    yes i too have the same problem. i am not having any songs in the player but my memory is full.
  • 626 Answers
The folder is hidden. You need to enable hidden files and folders in Folder Options on your computer. If you have the refresh database failed message often., you will need to format the device. Best of Luck.
Posted on Sep 09, 2007
  • Timothy D
    Timothy D Sep 09, 2007
    To format; connect it to your computer (in either mode). Go to my computer, right click on the device and select format.
    (If you do not see format, then select open, then right click on the ppi.nand, then select format.
    Do not select Quick Format unless you are using Windows Vista.
    Best of Luck.
SOURCE:
Yesterday I was creating a database template using mysoftware's My Database V6.5 product that I found on the internet (30 days free trial), I went to save the template and a huge portion of the template...
probably because free trials are only there to allow you to move around the program to see if it is suitable to your expectations
it is not there to use and save data as that is not the purpose of free trial
May 31, 2017 | Mysoftware MyDataBase (804526024423)
MAJOR Track Listing Order Screw Up...PLZ HELP
I no found samsung b310R usb modem driver on internet website
Apr 08, 2009 | Samsung Yepp YP-P2 Digital Media Player
N73 software prob
If your phone shut down during a firmwareupgrade there is not much you can do. Its probably busted.
Feb 03, 2009 | Nokia N73 Cellular Phone
I try to listen to one particular song, but Sansaclip 2gb freezes
Epsilon - delete that one song and see if the other songs play fine
unschool:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
BAD TRACK FOR EVERY SONG
The database has been corrupted, click HERE for how to properly format and reload firmware if need be...
Sep 30, 2008 | SanDisk Sansa e250 MP3 Player
All songs vanished after plugging into Mac
WHo knows what the Mac may have done. Try changing the USB setting from Auto to MSC.
Jul 08, 2008 | SanDisk Sansa m230 MP3 Player
Sansa 4GB mp3 player
corrupt database
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 08, 2008 | SanDisk Sansa e260 MP3 Player
My mp4 says empty disk
try to format it...or look at the folder where you place your songs maybe you missplace your songs...because there are specific folders where you should place your songs or videos....
Apr 30, 2008 | Audio Players & Recorders
No files found
Switch it to MTP or auto mode in settings menu
Mar 27, 2008 | iLO (2 GB) MP3 Player
No Database Found Error
i had exact same problem. one day i was messing about it wen i found out how 2 fix this problem.
1.switch off battery, then switch on
2.press play n sony logo should come n giv it a few seconds to load.
3.hold mode button for a few seconds n then keep hold of menu button at the same time- do this a few times if it doesnt work.
to my surprise this fixed the problem straight away
please reply if this works 4 u
i hope this info was useful 2 ya m8
Mar 20, 2008 | Sony NW-HD1 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
