Pioneer xd-j215m hi fi
Problem with tape decks, broken belt thought was an easy fix. Replaced the belt and for some reason would not play, would start and stop ff or rwd.Seems to want to start playing but play head would keep switching as if to play on reverse. then cuts off. Dis- assembled carriage and took a look.The head assy. and pinch roller get in position but tape spindle does not turn,looking from the front there are two little locking clips that I feel should slide up releasing the spindle to turn.This does not happen. Please help Thank you Ash
  • Anonymous Jun 24, 2008
    i have the saim problem with xd-j215m can you tell me the problem?can you help me?thank you
SOURCE:
  • 36 Answers
SOURCE: noisy capstan which runs continously
most tape decks are designed so that the spindle will run when powered on. when you press play or record, the pinch roller elevates the tape to the spindle, tape starts to travel.
noise is basically from the mechanism, or deteriorated in time as yours is an used one. if you are lucky to find some good pinch roller rubbers of same diameter, replace them.
pc-cook
Posted on Jan 25, 2008
  • 133 Answers
SOURCE: Tape deck turns on, operation sounds & looks NORMAL- yet won't function
Belts are prone to harden over time, like 10 years. The belt probably broke.
If you don't feel comfortable removing the housing yourself, take it to a repair shop.
Posted on Mar 21, 2008
  • 319 Answers
SOURCE: Denon Dual Cassette Deck DRW-660 will not eject either tape
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Posted on Apr 23, 2008
robotek
  • 1512 Answers
SOURCE: TEAC V770 3head tape deck.
Hi saabangerman
The unit sounds like it has a take up clutch or takeup idler problem. Check all the drive assemblies in the unit. Remove the cover from the front of the transport inside the cassette well, and check the condition of the idlers and reel base drives. The counter belt can also gatherup and prevent the takeup reel from working correctly, or fire the auto stop mechanism preventing it from playing, although that sounds to be ok in this case as the unit will FF and REW ok. The takeup drive is supplied by a different drive idler as it requires much lower and more controlled torque. This unit was always considered to be a great tape deck and is well worth a bit of attention for restoration. You can get a new belt kit for $19.00 from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
robotek
  • 1512 Answers
SOURCE: JVC KD-85 Cassette Deck Stops in Seconds in play, REW., & FF
Hineovision1
The deck will need new belts and idler drives cleaned and serviced, and perhaps some idler tyres replaced. You can get a belt kit from these guys. replacing them is not such a difficult job if you have some mechanical aptitude. Just take it slowly, and focus on getting the transport out of the unit.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
Posted on Jul 08, 2008
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
I have a kx-w4050 dual kenwood tape deck niether side will play hear click and counter moves one then another click. Is there a way to fix this?
Yes, the belts need to be check and idlers or whatever drive mechanism that is used in that system. Dual deck units are among the most unreliable units there are and a reason I tell people for the last 30 years not to buy those things. Almost most of the time they are not worth fixing due to their poor performance at the end. These are facts not just opinion.
Jan 14, 2013 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Tape deck door problem
The mechanism would not have reset to allow the door to latch on. it could be a possible failure of the main/dirve belt. you will also have to check if the hinges are broken or if any freign particles have logged in. Removing the deck mechanism and changing thebelt will require a little expert work and so be very careful in removing.
Apr 23, 2009 | Audio Players & Recorders
Hi, My Pioneer CTF-7272 Cassette Deck has stopped playing. Rewind works fine, but FF and Play will run for about 5 seconds and then the tape just stops. Any info on this problem is greaty appreciated....
check the belt whether it is broken or loose. if so replace the belt.
I hope this will solve your issue.
Good luck
If my solution proves useful please rank it.
Regards
Arjun.
Mar 27, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
Kenwood cassette receiver rx-28
There are sensor leaf switches that may not be contacting properly or the drive belt may be too slack to position meachanism properly. Have it checked by pro/tech
Apr 13, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Tape deck won't open
If this is a deck where the tape slides in horizontally, like most car stereo tape players, you may have a broken or slipping belt. The fact that you "haven't used it in a long time" suggests a worn-out belt.
In my car stereo, the belt slips when it's cold and won't play or eject the tape. After a few minutes, the unit "warms up" and the belt starts turning. Then everything is fine.
I think we both need to replace our belts.
Nov 17, 2007 | Audio Players & Recorders
235 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
