Question about Maytag Performa PAV2200
Maytag Performa Large Capacity Top-load Washer
The top half of the agitator separates from the bottom. Is there a way I can get it to stay in place again? I have tried pushing the top of the agitator onto the bottom half, but it soon works it's way loose again. Any suggestions?
  • Anonymous Mar 18, 2014
    cant pull apart top and bottom of the agitator
Krazytech, Just because your solution didn't work for me does not mean it won't be helpful to someone else who reads it. It was just not helpful to ME...but thanks for the personal attack. You may be a "Master" at technical questions, but you fail miserbly at customer relations. By the way, some people need help with THEIR spelling before posting THEIR negative replies.
Posted on Sep 17, 2007
  • 725 Answers
The agitator should have a SCREW, AGITATOR RETENTION that holds it on ..see brakedown. unless you are talking about the DISPENSER, FABRIC it should just snap on. let me know if his helps krazytech
Posted on Sep 09, 2007
  • Franklin Ouchida
    Franklin Ouchida Sep 14, 2007
    Not Helpful! so you don't have the screw to keep it on? Some people need help with there personality not there appliances.. Thanks for the negative rating..
  • Franklin Ouchida
    Franklin Ouchida Sep 28, 2007
    You rated Not helpful without a reason why? Did you put a screw in it. Did you try to snap the DISPENSER, FABRIC on.. Did you find a better Solution are you just too busy correcting other's spelling?
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
The top of the agitator does not move, but the bottom does.
There are little ratchet pawls that make the top 1/2 agitate in one direction only.... they cost about 7 bucks and 85 to install, not hard, just tricky to intall..
The secret to long life is to not overload and use more than enough water...
Sep 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Jul 29, 2009 | Maytag Performa PAV3200
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Agitator gear is stripped
just place both feet on the agitator as it sits on the floor and lift up on the top half. there are plastic tabs on the bottom half that hold the two pieces together. you will need to remove the 2 tabs before putting the 2 pieces together. the bolt that you screw the agitator down with will hold the 2 pieces together. Joe
Dec 03, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
573 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
