Question about Sony KP-53S70 53" Rear Projection Television
Red in the shape of a rainbow
I had the TV on and it seems the red color started arcing up in the middle and down on the left and right. I wasn't changing channels or anything. Any way of adjusting it? I know how to get the front panel off already if that helps you when you explain your diagnosis.
How do i get the colour menu to display on the screen?
Posted on Mar 22, 2008
    Genius:
  • 1,139 Answers
I have seen this before check your TV to see if it uses the STK-392-110 3 channel convergence module. If it does you may have to replace them (there are two of them). You may read something about replacing them with the STK392-150s but don't do it since the replacement requires the changing of the bias resistors, and you need to know ecactly what you are doing. You will need to desolder the the old modules and solder in the new ones (new 110s not 150s). I would advise you to get a schematic and check the voltages on the chips before changing them just to make sure they are bad.
Posted on Sep 09, 2007
SOURCE:
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
Red color distortion.
You have a Convergence problem. Most likely the STK392-120"s are bad and possibly a few resistors. Not something you should attempt if you've never done one. I would recommend calling a service co. in to repair it.
Apr 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Mar 15, 2008 | Panasonic CT-32SX12 32" TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Sony kp-51w5510 rear projection tv convergence
Lateral red or blue movement is accomplished electronically
via convergence alignment circuitry controlled by STK type IC's
Replace them both for reliability, then adjustments will work..
Nov 26, 2007 | Sony KP-51HW40 51" Rear Projection...
Green and red color problem on bottom left to a little past the middle of the bottom of screen
the convergence ic's are breaking down and require replacement should cost under $ 250 depending on your service shop.
Nov 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Red color alignment problem
1) Whenever a rear projection TV has convergence issues, the
fix involves replacement of both IC's = STK392-110.......sub to
STK394-160E for improved durability...........
2) Soldering only is a temporary "fix" at best
3) Do not allow generic IC's, OEM quality or better = I use
Hitachi brand,made by Sanyo,with no callbacks....
4) Skill level needed = above average,....needs chassis pull...T.
Nov 14, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Sony KP-53S70 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
