Question about Philips 32PT5441/37 32" TV
The entire picture does not show on the screen
Just recently the picture on my TV seems much larger than the screen itself. I no longer have my manual and can not figure out if there is a way to correct this. It is quite frustrating watching any tv because it cuts off any words it there are any. Any solutions?
Press the down button on your  phillps remote its prob on expand mode
Posted on Jan 06, 2008
    Problem Solver:
  • 7 Answers
CHECK SMALL TRANSISTOR LOC.# 7571 OR 7406 AND COIL 5405 AND COIL 5402 CHECK CAPACITOR # 2404 AND2552 OR BUY A KIT FOR THIS TV IS COST A ROUND 8 DLL YOU PROBLEM YOU HAVE IN HORIZONTAL CIRCUITY IN YOKE CONECTION CHECK A RAUND
Posted on Sep 28, 2007
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
How to adjust the screen size
On my remote control for the TV, I look for the # key and press it as many times as necessary to get the correct size picture that is needed to fill the entire screen. Sometimes for some shows, you cannot get the picture to fill the entire screen and then there is nothing you can do to get the picture any larger.
Aug 08, 2015 | Televison & Video
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Televison & Video
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
I turned the tv on. The green power/stand by
Question shows its Sony KDF-50WE655 dlp tv that has lamp inside and it seems its time to replace lamp.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual and please buy Sony original lamp for better result.
Thanks.
Mar 04, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Oversized picture problem
Several possibilities, if you use a set top box to get your signal like a cable box or satellite receiver they will have settings that effect picture size. It could be a high voltage problem inside the TV causing an effect called blooming, if that is it you can usually change brightness and or contrast and see the picture get smaller and larger. I don't recall that set having any customer settings that could give that symptom.
Sep 11, 2009 | Mitsubishi CS-40503 TV
LG TV - TV Guide Function Stuck
check the buttons on the remote and see if they are stuck or on the tv it self
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | LG 32LC7DC 32 in. LCD HDTV
The picture on my Samsung WS28A116D 100Hz with intergrated digital has suddenly changed in size the picture seems to be too big for the screen as it only shows what seems to be on the left 50 percent [this...
try unhooking the cable and hook up a dvd player see if the picture stays the same if it does then its the tv ,if its normal it will be in the transmitter.
Aug 30, 2008 | Televison & Video
DIBOSS tv shows no picture
Me too! Apparently Diboss are no longer trading, so no help there. I am aware that these panels have a common power supply issue, the faulty chip is only available from China and the last one I fitted only lastest a couple of days. However the fault described above is not the same. I've checked the psu outputs; all are fine and nothing changes when the picture disappears, therefore I can assume that I'm not looking at a PSU fault. As Iain says above, it appears to be a signal link, however I have no picture on ANY input and without circuit diagrams I cannot find any component that's common to all the various inputs. This leads me to think that either the backlight, or the screen itself is faulty. I'll keep trying and if I get it sorted I will report back.
Jon
Feb 27, 2008 | Televison & Video
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
Philips 32PT5441/37 32" TV Logo
118 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
