Question about Polaroid PDV-0701A Portable DVD Player
"No Disc" Error
My DVD player used to work just fine. Now I put DVD's in and I hear them spinning and the screen looks normal and says they are "loading." However, they never load and then I get a message saying, "No disc" when there is a disc in there. I've tried all kinds of DVD's new and old, and ones that have worked before and I get the same message. Not sure if the lens needs to be cleaned, if there is something else I can fix, or if it's time to get a new one. Please help! Hopefully, it's fixable as I haven't had the player that long.
  • 1 more comment
  • bambipurr Mar 21, 2008
    We also cannot load dvds anymore. It used to spend a long time saying loading but would get the no disk message. NOW we just get no disk error.
    This dvd player is only a year old! It is a slimline type you hook up to your television. We don't even hear the spinning anymroe. I tried cleaning it but that even said no disk!!!!!
    HELP! I am not able to afford replacing it ...is this a costly fix or can it be fixed by me?
  • bradleyjay19 May 21, 2008
    I have the same problem with this dvd player. It worked just fine for a couple years, now it says NO DISC after every dvd you load. it will not play anything. Any ideas?
  • florencio_re Nov 25, 2008
    no
    nononononononoonononononoonh
Does that work??? if someone has tried let me know.
Posted on Jul 29, 2008
  • 790 Answers
Cleaned your lens with 100% cotton buds, if not work again change the laser eye. do it!!!
Posted on Sep 09, 2007
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
Just Loading - Bad Disc
Normally I would say clean the laser lens, but I actually had the exact same model with the exact same problem, and that didn't work. I was able to get mine to work sometimes by turning it off and on and unplugging it, but even after opening it up, re-lubricating the gears, and replacing a few capacitors near the reader, I never did find a permanent solution.
I guess this isn't what you wanna hear, but I think its an untraceable problem with the motherboard.
Mar 25, 2010 | Cyberhome CH-DVD 300 DVD Player
DVD player says "no disc"
replace the player because laser lens is probably burnt out.
you can get a new player for 30 bucks at target or walmart
Jan 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
DVD player problem
you allneed to make sure the disc is spinning in the player you should hear it whirr as ut builds speed listen closely to it and keep a hand on it to feel when the disk quits if it starts. its supposed to spin v ery fast do you think you could tell by the sound of it if its spinning fast. some times they make a clicking noise because the drive mounts have slid down in the case and allows the disk to rub or tap the case. please let me know what you find out. this is for all three problems. let me know the results so i can further advise you.
Nov 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
two DVD player with same problem. I think they are disposable. :(
Dec 25, 2006 | Samsung DVD-V8500 DVD Player/VCR
Disk is "shot" out from the player still spinning fast
Maybe got damaged during shipping?? Try also to clean the lens. Theres not alot the consumer can do with a cd or dvd player as you need special equipment to work on these units as there are no user serviceable parts inside. If its a good unit maybe it would be worth a look at by a pro. Good Luck
Jun 26, 2006 | Pioneer DV-533 DVD Player
Polaroid PDV-0701A Portable DVD Player Logo
215 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
