Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
Screen cleaning Because of my touchy feely 18 month old daughter, I now have to clean the screen on my unit. I want to know the proper way. Thanks.
  • 29 Answers
Mix a solution of water and rubbing alcohol 10:1. You may add 1 to 2 drops of mild dishwashing detergent. Using a soft cloth, clean the screen in an up and down motion.
Posted on Sep 09, 2007
SOURCE:
I have a Dell Studio that's 18 months old and is has broken. The screen went blank and the light is amber on the on/off switch of the base unit. Would it be the motherboard? I am wondering if it is...
Yes, it's the motherboard - the amber light signals that the power source is in protected mode because something on the motherboard is shorted.
This is a big fault, other components might have been fried. Yes the pc can be fixed, but only by someone with hardware experience - a shop will be costly. Because of that it will be cheaper for you just to get a new one.
Nov 18, 2010 | Dell Computers & Internet
When I put a dvd in it try's to load and then it reads on the screen "no disc" and It won't play my player is only 5 months old.
Well, first I have to ask if it does load? If it does, and is not reading the disc, it will say, "no disc". DVD's in general are very touchy and the Memorex is not a high quality brand. If only 5 months old, it should still be under warranty.
Oct 23, 2009 | Memorex Televison & Video
Thermal Fuse keep failing
Fuse and element failure is related to lack of air passing over the element. The drum and fan should run even if the heater is inoperative. Find out what is stopping them, then work on heat. If motor is running, there should be air flow--pull vent hose from wall outlet--should be brisk air flow. If not, remove the lint screen and check again. If now ok, soak the lint screen in hot water and detergent. If drum does not turn, check the drive belt and if it sits properly on motor pulley.
Aug 01, 2009 | Whirlpool LER5636P Electric Dryer
Fuzzy Screen Display
this sounds to me that water has leaked into the screen
Apr 11, 2009 | Nintendo DS Lite
Flashing yellow light when charging
Clean your battery contacts with a pencil eraser and see if this clears up the problem. If not, your batteries may be needing replaced. When batteries get old or are shorting out this is common. Rechargeable 2-way radio batteries have the following life expectancies. NiCd 18-24 months; NiMH 14-18 months; and Li-Ion 12-14 months.
Jul 31, 2008 | Motorola Walkie Talkie 2-Way Radio
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Compaq laptop DVD/CD-R problem
get a lens cleaner cd insert it into your drive.... then check whether the pc detects the cd..... if it detects then u need 2 cleans ur lens properly.........
Mar 16, 2008 | Computers & Internet
Touchy Sound
a wire may have came unsoldered from the speakers, or plug, i would scrap them, unless you know how to fix it your self
Mar 11, 2008 | JBL Reference 210 Earphones (Black)...
Screen resolution problems
I just rang Samsung about this problem and they immediately said they would replace the monitor, no questions asked!
Oct 26, 2007 | Samsung SyncMaster 713BM 17" LCD Monitor
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
