Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Wont turn off, goes to magic focus
When you turn off tv it goes to magic focus. if you turn off again tv comes on. if you let magic focus run when it finishes the picture comes back on but with no sound,shut it off again and the sound starts working.shut it off again and the cycle starts all over with magic focus. tried unplugging for a while did nothing. this happened once before last year for 1 day and then started working right the next. any help would be appreciated.
  • Anonymous Mar 30, 2014
    My GVA wont turn on. After unplugging and leaving for a day it turned on, but once off would not turn on again.
  • 375 Answers
Enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Posted on Sep 09, 2007
Vertical position does not work on remote. Magic focus on green goes half way stops then number five comes on screen. Hitachi 51inch rear projection tv
Magic focus on a Hitachi only adjusts at 16 points on the screen and needs to be done in a dimly lit room. Frankly its a sales gimmick, the number 5 means one of the sensors inside the screen for the Magic focus is not connected or bad.
Go into the tech mode for convergence with the original remote (that menu is called the Decam mode) and see if convergence will adjust there. There are close to 120 points that can be adjusted there as opposed to less than twenty in the magic focus mode.
Dec 23, 2012 | Televison & Video
Hitachi 51S700 won't turn off
Some kind of a problem likely in the magic focus area--is the set showing a error on screen if you engage the magic focus?
One thing not to do is disconnect the sensors inside the screen as that could make things worse......
Dec 02, 2012 | Hitachi 51S700 51" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
TV will not turn off with remote or manually
That means that you either need to buy a replacement remote (or use an universal remote) , or you need to replace the TV IR sensor, that is a small board located inside tv.
Dec 15, 2008 | Hitachi 46GX01B 46" Rear Projection...
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
Sep 27, 2017 | Hitachi 46GX01B 46" Rear Projection...
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Blurred picture
try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Blue and Green Bar
run magic focus, If you get a error 4 during the magic focus, that is often an issue with the convergence
Feb 01, 2008 | Hitachi 51F500 51" Rear Projection...
65S500 will not turn off
Check to see if you have it set to do the Magic Focus on turn-off. It is in the menu under setup.
Nov 06, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Won't turn off
Go to the panel (on the tv set), hit magic focus on there....then hold power button for several seconds long. It should go off and fix your problem.
Jan 22, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
216 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
