Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
GE washer wont spin or wash
By JPsAppliance on Sep 09, 2007
i have a GE washer that will lock and fill but after 1 minute or less will unlock and do nothing can you help me out
Comments:
Sep 12, 2007
- actually i went back ran it through diagnostics and ecery thing works perfectly except for when it goes to test the spin or tumble the display just shows 00 and wont do anything but the door dock stays locked throughout the entire diagnostics so im thinking its the inverter?
Same Problem
Jan 07, 2009
-   my ge washer will not spin or agitate everything else works-   charles456
Dec 25, 2008
-   My GE washer will not agitate or spin.Everything else works, fills pumps out, just no agitation or spin dry. -   frets132
Sep 20, 2008
-   I replace a electronic control board to my Ge washing machine model EWA4500D and when I plug the power all led lights start blinking
I need to know ho can re-program the machine-   jortiz93
Dec 11, 2007
-   WASHER ATF7000FSO,WONT FINNISH CYCLE. WONT SPIN , WHEN CANCELED ANY TOUCH TO SELECTOR OR CANCEL OR START WILL TURN WASHER ON ?
-   CONTROLDUDE
Solution #1
posted on Sep 09, 2007
Somewhat Helpful)
dovi
Rank: Guru
Rating: 88%, 2495 votes
It sound like a lid switch issue.
The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch.
Look if the switch is broken or loose. In case it looks OK mechanically, it might be defective electrical and should be replaced. Good luck!
Was this helpful?
Yes
No
Solution #2
posted on Feb 04, 2009
Not Rated)
ninahgill
Rank: Apprentice
Rating: 0%, 0 votes
I have a English electric washer/dryer, model EE100WD..The water fills up, but the drum wont turn, but I can hear a humming sound. I can turn the programme switch to drain the drum and that works. Could it be that the brushes need replacing, as it looks like one of the carbon brushes is broken....thanks Nina
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
elite oasis is that a quaitly machine
Answer
What is the most reliable top loader washer to buy?
Answer
I have a used malber p18. all the hoses are connected but the washer will not fill with water. What... (More)
Answer
Ariston Gas Boiler error code E02 what is the problem. No other boiler specification on the type of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
