Front load GE wont spin or wash
I have a GE front load washer that will fill and drain but it will lock the door turn the drum half a turn and less than 1 minute will unlock the door and do nothing could you help me please thank you the model is GCVH6260FWW
  • Joe Potter Sep 09, 2007
    well its about a year and a half old and im assuming it wont spin because the door unlocks but while the door is locked and when the motor breifly runs it sounds good so im assuming this leaves the electronic board , the door lock or the inverter do you know offhand which one controlls the door lock this is a customers unit and i have never worked on this style before thanks
  • Joe Potter Sep 29, 2007
    the problem was the inverter board was defective i just replaced it and it works good thanks for trying though
  • 725 Answers
I can't find your models breakdown but it sound like a bad motor. if it drains and fills you have a good pump. if you had just a bad motor control if mostly would agitate. If the motor hums then you are getting power to it.. if you have no hum you can check for power with a meter.. if no power you have a bad control.. if you have power you have a bad motor... let me know what yo find out.. krazytech
Posted on Sep 09, 2007
  • Franklin Ouchida
    Franklin Ouchida Sep 09, 2007
    the main board controls the door lock. So if you have a bad switch in the door lock then then it also will not agitate or spin. let me know what you find out..
SOURCE:
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
My ge front loader will not spin. the door is
My front load washer will not spin or the drum will not turn on the wash or spin cycle.
Dec 13, 2009 | GE WBVH6240F Front Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Spin cycle not working
try the door switch the washer will do everything but spin if the door switch is faulty
Jul 13, 2008 | GE Profile WPSR3120WWW
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Feb 16, 2008 | GE WSXH208A Front Load Washer
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
GE washer wont spin or wash
It sound like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look if the switch is broken or loose. In case it looks OK mechanically, it might be defective electrical and should be replaced. Good luck!
Sep 09, 2007 | Washing Machines
Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Apr 18, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
323 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
