Home | IBM | ThinkPad T41 PC Notebook | IBM Thinkpad T43 fre...
IBM ThinkPad T41 PC Notebook
Problem for IBM ThinkPad T41 PC Notebook
IBM Thinkpad T43 freezes until pressure is applied to the top
By spam458 on Apr 10, 2009
I have a very puzzling problem with my laptop.
The computer will sometimes completely freeze. No hard drive activity, no mouse response, nothing. This bug is platform independant. It occurs in Windows XP as well as a linux invironenment that I boot into via flash drive.
The only way to unfreeze it and continueworking is to apply pressure either on the keyboard or on the left or right corners closest to user in front of the keyboard. I have removed the keyboard and tightened up all screws that were accessible. I have also removed the hard drive and blown off the connectors with dustoff.
Another unusual bug that has arrisen with the freezing bug is that my laptop will accept drives connected via USB for a little while, but then disconnect them. After this disconnection happens, windows will give me a notice that the usb device could not be recognized and is likely to have malfunctioned. All of these drives work fine on other machines, so I know this is not the case.
Has anyone else had this issue? Any solutions? I'm extremely tight on money at the moment, so a new laptop or even a new MB is not an option. I can only hope it's a simple fix!
Thanks All --
Same Problem
May 20, 2009
-   I have precisely the same problem in a T43p-   Guest
May 14, 2009
-   I have literally the exact same problem... and i'm out of ideas. It works for awhile and then freezes until it's either balanced at a specific angle or pressure is applied to the front corners or middle. I've taken it apart and nothing obvious seems to help. Any ideas? -   kleedham
Solution #1
posted on Jun 15, 2009
Not Rated)
dmanella6
Rank: Apprentice
Rating: 75%, 1 votes
I don't have a solution to this problem but I know what the issue is because I have bought several of these unit and they all have one of two problems.
1 If they have the ATI X300 Radeon video then it is a GPU issue that has plague the T4x series and I believe it migrated into the T60 as well this is a very disturbing issue in the sense that IBM/Lenovo has known about this problem and won't take ownership and have a recall. The cost of these machine's are unbelievable when new and to have a problem like this it is unacceptable.
The other issue is the Southbridge and it has the same problem as the GPU, which is a solder problem.
The solder joints between the board and the BGA become cracked and cause intermittent issues such as freezing, HDD not to spin ETC practically everything runs through the Southbridge (PCI controller) even video control signals and USB.
The cause is flexing of the motherboard over time
Solution 1.
Find a place that does this type of rework there are some companies offering this service but do your homework before hand I am in the process of getting one of these boards done but the cost is not cheap. I think it is cheaper then getting a new motherboard
Solution 2
Get a new motherboard $400.00 and after three or four years have the same problem.
I hope this helps. Dee
Was this helpful?
Yes
No
Popular Solutions for IBM ThinkPad T41 PC Notebook
Questions and Unsolved Problems for IBM ThinkPad T41 PC Notebook
Do you recommend IBM ThinkPad T41 PC Notebook?
Answer
Answer
hello there how to switch the letter key back to letter type
Answer
I am trying to replace my t41 monitor. I need instructions. Can you please help? THanks!
Answer
I had this T41 for 4 years. The only thing I've changed is an additional 512MB memory which was... (More)
Answer
Anytime I try to use a USB 2 device, my Windows XP system shuts down. I took it into a good, local... (More)
Answer
my soundcard is not working under winXP. I am using a HP T41 laptop. With Ubuntu Linux, there are no... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM ThinkPad T41 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
