Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon pixma Hi im trying to figure out how to load paper into my new canon pixma
Lift up the flap at the back you load the paper in there hope this helps
Posted on Sep 23, 2007
How do I load paper into my Canon Pixma MX452 printer?
A lot of times the printer has a small piece of paper jammed in it or has had a jam and will not recognize the new paper. Try this to see if it resolves your issue. http://www.wikihow.com/Clear-a-Paper-Jam
Jun 25, 2014 | Canon Pixma MX452
Canon pixma pro 100 - "support code : 1000 no paper. Load the paper in the rear tray correctly and press the RESUME button on the printer". How do I fix this?
Try again! Remove the paper from the rear tray. Turn off the printer. Load the tray again making sure that it pressed frimly in and not over loaded - say about 30 sheets. Turn printer on again and see if it is ok. If still the same problem, get in touch with supplier or maker.
Mar 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
CANON PIXMA IP2200 DOES NOT FEED PAPER
Paper not feeding into Canon Pixma MP210 printer
Several suggestions here include printing a heavy card instead of regular paper, or turning the printer upside down to remove any object like a key stuck in the printer.
Dec 20, 2017 | Canon PIXMA iP2200 InkJet Photo Printer
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
My cartridges on my canon pixma mp190 do not move to the center when i open it. it is also blinking an error of E2 and the alarm button is blinking
Is it brand new? The print head rail may have a protective plastic piece covering it. Pull that out and it should work better.
The code "E2" on your Pixma MP190 indicates that the paper is loaded incorrectly.
After correcting the problem that caused the error, press the or button.
  1. Remove paper from the rear tray.
  2. Open the paper output tray and extension. (See and in Figure 1 below.)
  3. Set the paper thickness lever according to the media being used. (See in Figure 1 below.)
    Note: For paper thickness lever settings, use the following setings for the media type being used: Right side: Envelopes / T-Shirt transfers. Left side: All other media types.
    * Figure 1
  4. Divide the stack of paper into two or three piles.
  5. Fan out the sheets of paper so that they do not stick together.
  6. Load paper in the rear tray with the paper's print side facing up. (See in Figure 2 below.)
  7. Align paper to the right edge of the rear tray. (See in Figure 2 below.)
  8. Pinch and slide the paper guide to the paper's left side. (See in Figure 2 below.)
    * Figure 2
  9. Press or button to clear the error.
Dec 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Printer says no paper, but there is. Problem loading?
If not paper jam may has some problem with feed rollers on printer.First make sure that option to feed from cassette is turned on.Check this on maintenance mode.Аs the printer is in warranty better don't touch anything else and call Canon.
Nov 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp460 feeds more than one pages
Hi ...
There is no hardware fault in this perticular situation. This happens because of paper loaded. There are 2 possible resolution to this problem:
I) Fan paper prior to inserting it into the MP460
  1. Remove paper from the ASF.
  2. Open the paper output tray. (See <2> in Figure 1 below.)
  3. Set the paper thickness lever according to the media being used. (See <3> in Figure 1 below.)
    * Figure 1
    The illustration shows the PIXMA MP460
  4. Fan out the sheets of paper so that they do not stick together.
  5. Load paper in the auto sheet feeder with the paper's print side facing up. (See <1> in Figure 2 below.)
  6. Align paper to the right edge of the auto sheet feeder. (See <2> in Figure 2 below.)
  7. Pinch and slide the paper guide to the paper's left side. (See <3> in Figure 2 below.)
    * Figure 2
II) Load fewer sheets into the MP460
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Loading paper-how?
You put the paper in the top, and it comes out of the bottom.
Remember to vote.
Dec 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Streaky pictures
hi, your head has damaged/need replacement. Try to clean it once again
thanks
Aug 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
136 people viewed this question
Clive
Clive
old marine
old marine
