Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hard disk how to move or copy any data from one hard disk to another hard disk.
  • Microsoft Master
  • 12,061 Answers
There are a few ways to do this.. First is a USB Memory Stck, or the like. Then there is Networking the two PC's together with a cross-over cable. There are also USB devices exactly for that purpose for sale. The you can use an SATA/ IDE-USB adapter and take drive out of one machine attach to adapter, and plug it in to "Other" machine's USB port, and it will show up as a local drive, then ya can cut & paste etc. There are programs for "Cloning" entire drives, or just copying some files or data using any of various methods above.
Posted on Sep 09, 2007
SOURCE:
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
Transfer data and operating system from one hard drive to another
Use AOMEI Partition Assistant,a free Windows partition software, to clone data or OS from one hard drive to another. http://www.disk-partition.com/copy-disk-partition-wizard.html
Oct 12, 2012 | Hitachi TravelStar Computers & Internet
I have purchased the lenova laptop in which th Hard Disk is from Hitachi and my data is in the Hard Disk how can i get back my data
You can use an external Hard disk and transfer your data.
If you want to transfer it exactly as it is, U can remove the Hitachi Hard Disk, put it in a hard Disk case, and use it as an external hard disk
Mar 01, 2011 | Computers & Internet
Samsung sp0802n hdd, failure is imminent back up data and replace. wont let me, just goes back to the BIOS screen.
The disk is about to fail and Windows is corrupted. Boot from a Linux Live-CD and copy all your data to an external hard disk. Then replace the hard disk with a new one and junk this one, reinstall Windows and copy all your files from the external hard disk in the new internal one.
Oct 16, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hard drive
yes you can download it . just connect the drive to your computer and move files from the hard disk to your hard disk.
or
you can use a pendrive and copy required data and disconnect it
Apr 19, 2010 | Sabrent SBT-WCCK Webcam
Need to recover data from gateway 310xl. motherboard shot. hd good. any ideas?
Unplug the hard disk and put it into an external USB disk case.
Now just plug the disk into any other computer.
If you have Windows encrypted data on the hard disk, it's more difficult: the new computer will not be able to read the data.
Start by doing an exact copy on another disk, just in case. Then you can try swapping the COPIED disk with that of a working computer, the more like a 310XL the better, and do a "OS repair install". This will safekeep user data, identity and crypto keys, and allow access to the data. If it goes wrong, you only screwed a copied disk, not the original, and can retry regenerating the copy and maybe virtualizing it with QEMU or VMware.
Oct 28, 2009 | Gateway 310 XL (310XLSP) PC Desktop
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
I can't delete files from my 160 GB Simpletech hard drive and it is full, what should I do?
Do a "disk cleanup"
Click on [My Computer]
Right-click on the External drive (D?)
Select [Properties]
In the [General] tab, click on [Disk Cleanup]
It will "scan" your drive, but not remove anything... alow it to complete the scan.
Look at the recommended list that appears and accept its findings.
This should remove non-essential files and leave your data intact.
Burn some of your data, especially video content to DVD (make at least two copies) ... then remove the data from your external hard drive.
You may want to purchase another (larger) external drive. You can use two of them or move your data to the new one.
Sep 30, 2009 | SimpleTech Signature Mini 160GB External...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
