Question about Toshiba 42H81 42" Rear Projection Television
STK392s didn't solve the problem
Red convergence won't move left or right even in the service mode.
  • 372 Answers
Hi. Im not 100% familiar with your model toshiba but they are all similar so try this. (1) RESOLDER MEMORY ICS ON THE TEXT BOARD, A COUPLE OF THE LEGS LIFT OFF THE BOARD. (2) RESOLDER ALL PINS OF THE OUTPUT IC'S, EVEN THOUGH THE DON'T LOOK DRY: Q750,Q751 AND Q753. RESET CONVERGENCE IN SERVICE MODE. CHECK RESISTORS, CPS, & REPLACE ANY BULGING CAPACITORS NEAR THE CONVERGENCE ICS. As I said im not to familiar with your model it may or may not have the exact components I have listed in parts (1)&(2) But its worth checking just in case it does.
Posted on Sep 09, 2007
SOURCE:
Can't converge red on the edges
Depending on the actual model number the set uses either one or two convergence chips and both would now have to be replaced.
Set as you know has convergence mode in customer menu and another in one of three hidden menus.
Jun 17, 2012 | Mitsubishi WD-65000 65" Rear Projection...
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
Red Converance problem
Don't try to solve this in the service menu. The lines that do not move in the customer convergence menu will not move in the service menu. And, you can do some serious damage if you hit a wrong button while in the service mode. You have bad convergence output ICs. You can expect to spend $350-450 to have this problem fixed by a qualified technician.
michtech
Sep 19, 2008 | Toshiba 65HDX82 65" Rear Projection...
Convergence problem not fixed after replacing STKs
I found the chips easy to replace, but time-comsuming due to the number of pins involved. I woudn't want to try it if I'd not had prior experience with soldering.
Still no response to the original question though. With 2 replaced STK392s, red is still not moving in horizontal alignment. What gives?
Aug 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 43FDX01B convergence red line wont move
probably need to replace STK IC on convergence board and possibly associated low value resistor
May 09, 2008 | Hitachi 43FDX01B TV
Rear projection 43" Tv
The black box with 4 large red wires in it is the high voltage distribution box. One red wire brings the high voltage in and the other 3 bring high voltage to each of the 3 picture tubes. If those red wires are not all the way in and tight, then there will be high voltage arcing inside that box and the picture will rapidly flicker. Make sure all red wires are pushed all the way into those holes and your picture should be back to normal. Convergence IC's will not make the picture flicker, so I am sure your IC's are fine.
Mar 18, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
