No power the the interior of the van.
5.4L V8 yes. BUT IS IT AUTOTRANSMISSION, TOSS COIN YES.
all fuse must be good. we test them
OBD2 pin 16,12vdc goes to 1 fuse. and is blown, or DC power to the box fuse is dead. see those huge fuses 50amps up those?
YOU did not say head lamps work
or if starter motor clicks, or chatters or spins at all. sure SILENT.
1: battery load test fails hard, (a tool)
2: all battery cables , all 4 ends, not rusty and are TIGHT.
3: all huge fuses are not blown (50amps up)
4:;all lower amp fuses, not blown. we test all fuses.
5: fuse link A not blown up, feeds Starter RELAY TOO.
6: with dead starter the stater relay is heard to click does it?a 2man test sorry.
lots of fues-able links on car, A to E or more.
12.8v at battery but turn on head lamps.? at the same time.
meter neg wire , black must be connected to the NEG lug of battery for all voltage tests or things go worn,(meter lies)rule#2 first.
if power DC is dead to cab box that fact (battery good) means
the power under hood failed, and is huge fuse for that.
the schematics are on line to see them.
FOR the starter relay to work the the PRNDL must be in P or N,
switch not bad or no cranks happen. the trick is Shift to "N" and crank,
fuse 23 not blown bay , 50amp
fuse 34 not blown cab, 10amp/
head lamp tests are first, high and low and not dim.
and battery voltages hold.
and HL work key on and key off do they?
for HL to work ,besides it's relay fuse link B and C must not be blown
both links go to battery PLUS. HOT all times.
so head lamps are always tested first, the acid test, 1.
then cranking, if all fuses test good. and you did miss lots
if the battery passed load tests.
