Question about Toshiba 55H70 55" Rear Projection Television
Toshiba 50" cinema series
My set wont turn on. normally the on/off button is black when off and a solid red led light within it is on when the set is on. now the led lights constantly flashes and the on/off button has no effect. any ideas what this is? thanks!
  • borderline Dec 24, 2007
    set will not turn on red light flashes.it works some times if i unplug it and plug it back in how ever it did not work this time
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Posted on Dec 23, 2007
I NEED T.V CODES FOR A ADMIRAL T.V AND NEED STEPS ON HOW TO SET UP CODE FOR A INNOVAGE REMOTE
Hello
Code for Admiral TV with Innovage remote control are:
001,173
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
Mar 27, 2011 | Innovage Jumbo Remote Control
I HAVE 2000 TOSHIBA 50" CINEMA SERIES MODEL 61HX70. WHEN I TRY TO TURN IT ON, IT DOESN'T WORK, BUT THE RED LIGHT FLASHES CONTINUOUSLY. WHAT CAN I DO?
U have tools lilke a soldering iron,solder,desoldering pump or soldering wick?U know how to do basic soldering?Try website like Tvrepairworld.com to buy a capacitors kit,to fix the DM power supply board,will fix this problems.
Sep 09, 2010 | Toshiba 50HX81 50" Rear Projection...
2000 Toyota Corolla wont start Changed 02 sensor disconnected bat
that red LED is the Alarm, if its solid red, its fine; blinking is about to trigger I think and off means the Alarm is active and opening a door will set it off.
as to why it wont start...not a clue,
check gas, make sure its in park,
you said its turning over but not firing, perhaps its a bad sparkplug or just flooded...
Apr 17, 2009 | 2000 BMW 3 Series
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
1999 Toyota Corolla security system
Yes it does, there should be a black small button under the drivers dash .could be hidden so look with a light, once you find it you need to turn your ignition on then turn it off and press the button within 10 seconds the LED should turn off and the alarm should be working normally
Sep 23, 2008 | 1999 Toyota Corolla
Codes for jumbo remote
TV codes 0013, 0018, 0028, 0031, 0034, 0043, 0046, 0052, 0058, 0072, 0081, 0084, 0134, 0135, 0141, 0150, 0162, 0182, 0187, 0199, 0208, 1019, 1033, 1036, 1071, 1077, 1149, 1150
vcr codes 4015, 4032, 4012, 4020, 4052, 4017, 4039
Turn on device that you want to set
Aim remote at the device
Press the device button for the item you wish to program and the LED will blink once
Press and hold the set button unti the LED lights up solid red
Using the number keys, enter the 4 digit code from the list. After you have entered the 4th digit, the LED will turn off, indicating that the code for the device was recognized.
If the device powers off, test the functions for the other buttons (except OK button). If all the functions work, press the OK button to store the code. If the indicator light remains solid red after blinking 3 times the code is incompatable. You then need to restart back on step 2.
Make a note of the correct 4 digit code for future use.
COde search setting is an alternative method to programming your device without using the code list
Turn on the device you want to set
Press the decive button for the item you want to program
Press and hold the SET button until the LED light up solid red
Press the MUTE/SEARCH button. The LED will shut off first then light up solid red.
When the device turns off, press the OK button to store this code.
Code Retrieval
Press and hold the device button you want to display on the remote control
Press the NUMBER 1 then count the number of flashes
Press the NUMBER 2 etc
Press the NUMBER 3 ets
Press the NUMBER 4 etc
If the LED light flashes 10 times the number is 0
Aug 18, 2008 | Televison & Video
Remote code
Looking for other codes, but while im doing that you can try
COde search function is an alternative method to programming your device without using the code list
Aug 09, 2008 | Televison & Video
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Innovage jumbo universal remote
Code Retrieval
Jan 23, 2008 | Audio Players & Recorders
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba 55H70 55" Rear Projection Television Logo
402 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
