Question about Hoover F5906-900 Upright Steam Vacuum
Water lines my daughter was trying to fix the unit and we don't know how to hook the white and black water lines up.
  • 625 Answers
Go to this site. they have your vac listed. when you click on parts for your machine - an exploded diagram for your machine will show up with a list of repair parts. http://www.thehooverstore.com/F5843.html
Posted on Sep 11, 2007
Replaced Oreck power switch. 2 black leads and 1 white lead for switch. Posts marked 1, 2, and 3. 2 black wires to switch powers on. Connect white wire and breaker trips. Where does the white wire go?
Both black go to the switch. Power in - black to switch / white to white from motor.
From motor - black to switch / white to white from power cord
The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
Nov 01, 2010 | Vacuums
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vac has nosuction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
If you need pictures, let me know.
Nov 07, 2009 | Bissell 9200 Upright Vacuum
My Oreck XL has worked very well until the power cord was pulled out of it. I figured how to hook up the hot but can not figure out the neutral connection. any ideas?
if there are two wires it doesnt matter normally white 2 white and black 2 black if its 3 wire than green is ground and the other 2 dont matter thanks Don
Oct 31, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Will not **** water
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
Sep 16, 2009 | Bissell 9200 Upright Vacuum
My daughter purchased a Steam iron Make
Don a thermo fuse can generally be bought at an electronics parts store or Radio Shack type outlet in the hobby parts area. Like any other fuse they are rated specific to the requirement of the appliance, do NOT use a higher temp one.. If you have warranty, ( likely 1 year???), return the iron, If you replace it, it is generally an in line crimp. I would only attempt it once as the iron may be defective.
Sep 11, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam cleaner will not **** up water
Apr 08, 2009 | Bissell 9200 Upright Vacuum
1699 ProHeat Clear View Upright Steam Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49925&thid=639852
Posted by wmwmsjr on Jun 02, 2008
when the clean water tank is filled and set in the proper position the water steadily dumps on the floor when i inspected under the unit you can see the white rubber diaphragm approx. 3/4" in diameter exposed and you can see what i assume to be the suction line for the clean water when the handle is pulled it appears that there would have to be another part here some sort of cover or something to assist the diaphragm in holding back the water from dumping out of the tank until the handle is pulled does anyone have any photos of the bottom of the unit or know where i can get this part any thanks is much appreciated Bill
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There is a valve under the water holding tank that is probably giving you a problem and it is replaceable depending on if it is underneath the water holding tank or directly under the water tank. I am going to give you some phone #’s and websites that you can order parts from or fell free to contact your local vac dealer in your area for service and or parts.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Bissell 1699 ProHeat Clear View Upright...
Hoover F5906-900 Upright Steam Vacuum Logo
53 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
