If you wanted to, you could wrap this command up in a VBScript and execute the test page from there. For more information about running command line tools from within a script take a gander at this classic Tales from the Script column (it’s actually the first Tales ever written
To turn the Silent Mode OFF for your handset to ring, press and hold the # key on your handset for about 10 seconds. Your handset will beep and this will indicate that the Silent Mode has been turned OFF.
Its very easy to do matrix operations in FX 991ES This calculator can operate up to three Matrices at a time, namely Matrix A (Mat A), Matrix B (MAT B), Matrix C(MAT C).
First to do, is set the calculator in MATRIX Mode Its Easy Press MODE button and press 6. Your Display will show indication of MAT on upper side of screen to show now calculator is in MATRIX Mode
Now we need to Define matrices and set its dimensions. This product supports matrix of order up to 3x3. That is you can operate matrix of No. of rows=3 and No. of columns=3 To input matrix, Press SHIFT and then 4. This will Pop up Menu for Matrix. Now press 1 Your screen will show as this,
MAT A will be your First Matrix and MAT B will be your Second Matrix and so on. Press 1 , 2 , or 3 to select Matrix A , B, or C. here I will Proceed with Matrix A, so I press Numerical 1 Key
Next screen will ask you about the size of matrix.
Press UP or DOWN Keys to view options.
Press Corresponding Numerical keys to select corresponding order.
On Next Screen , enter values on each positions
Press UP, DOWN, LEFT, RIGHT Keys to move around in matrix and specify each element.
Now we inputed Details about Matrix A. If you want to specify other matrices (MATRIX B, MATRIX C) repeat STEPS 2 To STEP 4
After Specifying required Matrices, we can tell calculator to do operations with them.
Press SHIFT and then 4 and then It will show a menu contains
For example, i need to multiply Matrix A with Matrix B, i'll enter as
SHIFT + 4 + 3 to Input Matrix A X to enter operator (Here multiplication, You enter + - x / for corresponding arithmetic operations )
SHIFT + 4 + 4 to Input Matrix B
= To show Result Press UP DOWN LEFT RIGHT Keys to view extra fields, if any.
It is just a matter of being in EXACT mode. To set your calculator in EXACT mode here's the key sequence. Press [MODE] [F3] [Up Arrow] [Up Arrow] [Right Arrow] [2] [ENTER]. Now when your in the Matrix Editor you can input your numbers in decimal form and, they will be automatically be converted to a fractional format. Pictured below is a matrix that was entered using decimal numbers and, was converted into factional form. Notice at the bottom of the screen the calculator is in EXACT mode.
Here's the same matrix in the HOME screen.
Next is the same matrix converted back to decimal numbers. Notice at the bottom of the screen the calculator is in APPROX mode.
And of course when I turn the calculator back to EXACT mode and, Re-ENTER the decimal formatted matrix in the HOME screen the fractional formatted matrix reappears.
You can use the propFrac( command but, having in the EXACT mode setting works better.
Press MODE 6 to get into matrix mode. Note: do this only once. If you do it again, it will erase all your matrices. Pick the matrix, set its dimension, then the calculator will put up a screen allowing you to enter/edit the matrix elements. At any time you're in matrix mode, press SHIFT 4 to bring up the matrix menu.
All this is explained in the manual beginning on page E-57. If you've misplaced the manual, you can download a copy from http://support.casio.com/manualfile.php?rgn=1&cid=004001004
You can download the manual and the appendix from
To compute the tangent of an angle, press TAN and enter the angle. Make sure you have the appropriate angular mode (radians or degrees) set first.
Press MODE 6 to get into matrix mode. Once in matrix mode, SHIFT 4 will bring up the matrix menu for further operations. Be careful and don't press MODE 6 again or it will erase all your matrices. To get out of matrix mode, press MODE 1.
