Question about Nordic Track C2400 Treadmill Walking Deck
The motor does not come on when you turn on the power. The display lights up like it is trying to work. When you punch any of the buttons nothing happens except it beeps at you. The fan does not work. The audio connection does work. The reset button was not tripped. The reset button functions to cut off the power to the display and the unit beeps back at you as you restore or reset the power. The unit was not used for a few months and when we cut it back on this was what we found. Before this it was functioning well.
    Habit-Forming:
  • 138 Answers
When you press the buttons do they change anything on the screen? If yes then you have a bad controller, if no you have a bad console.
Posted on Jun 16, 2017
SOURCE:
  • 4 Answers
SOURCE: The digital touch screen display is not showing
What your seeing is a common problem which I encountered on 3 separate displays. I have since diagnosed the problem and am currently life-testing a working solution. The real problem is very poor design of the negative voltage generator circuit for the display contrast. Everything else is working fine except that circuit. I have designed and installed in my treadmill a replacement circuit that is much stronger and am currently testing it. zubatcha@gmail.com for more information
Posted on Nov 01, 2010
2manyhobbies
  • 135 Answers
SOURCE: My C2255 will try to start rotating for a second
Remove the motor hood cover. Under the lid is a tech sheet. There you will find the service mode calibration procedures and an explanation of what the flashing LED means on the motor controller.
It sounds like an overcurrent shut down.
Listen carefully to the operation of the controller PCB. When start is pressed, you will hear a relay clik. Watch the motor for excessive sparking. Upon shutdown, you will hear it clik again (off).
Unplug the machine, disconnect one of the motor wires, either red or black. Plug in the machine and start it again, listening to the controller. if they relay now stays on, I would suspect a defective motor (drawing too much current).
Posted on Dec 19, 2010
ercupa190
  • 12223 Answers
SOURCE: My NordicTrack A2050 no longer
Watch this video and Step:
http://www.youtube.com/watch?v=E-q-uS4t6so
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
    • 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position
Chech: Optical Sensor if have it.
Posted on Nov 09, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill won't start. Console works but when
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Posted on Nov 21, 2011
No picture display or image when I turn the camera on
Did you try to press the display button on the back of the camera?
With the display button you can cycle through different things on the display. One is power save and it will display nothing. Perhaps that is everything you have to do. If that does not work, let me know.
Dec 16, 2013 | Canon PowerShot SX30 IS Digital Camera
LG 47LV4400 doesn't work but back light turns on
Start by measuring the various power supply voltages and see if some are missing or incorrect.
Dec 29, 2017 | LG Televison & Video
M2727 MFP no lights on the display
probably a cable is loose or not connected for display. printer could be faulty or you mught fix easily.
Aug 20, 2009 | HP M2727NF Laserjet Printer
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Kawasaki zzr400 (1994 model),streetfighter wont start
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
Jan 22, 2009 | 1997 kawasaki ZZR 400
ASUS Z91H PUSHED POWER BUTTON BUT WITHOUT DISPLAY
Try pressing the power button and press [del] button. See if it goes to the bios setup page. If it does, have your harddisk checked. It could be corrupt OS or problem with your harddisk.
Sep 12, 2008 | Computers & Internet
Camera won't turn on
I am assuming that the power does not go on or it immediately turns off as it is turned on.
Try the docking station or the 3.3 AC adapter to the camera. Plug that in to live power. If you hear the lens motor (by default the lens is retracted to closed position when plugged to AC power), then the camera is operational. If not, there is power failure with the camera.
If the lens motor work, then try to turn the camera while plugged to AC power. If it turns on, then there is something wrong with the battery or with the chamber. If the camera does not turn on, then check the button board for a bad power switch.
Check the LCD closely under a bright light when you do this test. You may see a faint a flash of display that disappears. I have not figured out what causes this. This would mean that camera power supply is working but nothing is telling for the camera to stay on.
Aug 02, 2008 | HP Photosmart M407 Digital Camera
Default setting
Your machine is old analague and a few years old now.It should be no problem changing.If your exposure settings are out it may be drum wear but more often or not all mirrors needing good clean.
Off top of head....M/c off..hold down 0and 8 numerics and power on...AD or AJ on display.punch in 15 and press print..... should read 00 on display... punch in01 and press green print button..press 09 and m/c ready to go if not switch off and on.
If unhappy with auto expose or manual middle expose...0+5 power on...AD or AJ on display,punch in 0+1 then print key opens exposure....pressing 1 increases light each press,,,try poss.10 times and print after to load.. and 7 decreases light to darken then print to change value. 0+9 together will get m/c to ready please try, all the best.
Mar 27, 2008 | Toshiba 1360 Black and White Copier
Nordic Track C2400 Treadmill Walking Deck Logo
369 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
