Question about Toshiba 37RV635DB Regza 37-inch Widescreen Full HD 1080p LCD TV w
Toshiba regaza 37rv635db wont turn on
Turn power on at main side switch. LED 1 green light. led 2 & 3 off. After approx 10 secs green light turns red. Unable to get any picture. Have attached xbox & digibox to ports to input a signal. Remote ctrl appears to work ok on other tv. Side on button held for a few seconds & green light on again for another 10 secs then red again. Have checked capacitors for leaks & bulging. No dry solder joints apparent. Any ideas please? Many thanks.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Seems like capacitor problem, chack them and if thay have exploded replace them.
Posted on Aug 25, 2013
SOURCE:
  • 52 Answers
SOURCE: Red Blinking Light
These types of problems are allways hard to diagnose.. If you were to power on the set and preform tests, you would think that everything was fine until the moment it shuts off.
Look on the main power board and see if you cant find the thyristor (thermal switch), those are the things that when heated will cause the set to power off for safety reasons.. They are normally placed where ever a large heatsink is. That may give you a location as to the problem and you can put a meter around its 2 pins with the set off and unplugged a couple of min after failure, if its short (0 ohms) thats not the problem, if its open, it triggered the event.
Second, you can run the set for a while and check the voltages and Ve, Va, VCC, Vsetup etc and compair to the markings on the plasma PDP sticker. If you see one is falling down over time (volts will be lost as heat) then you can isolate that portion of the supply.
Third and allways the best way to go about these problems is buy a thermal gun and moniter various spots for heat.
Its just vary hard to say, resistance could be off somewhere, diodes could be overheating as well as fets and caps. Thats why a good thermal gun can point you to exactly where the problem is.
Hope this info helps, but I would suspect the problem is on the main power supply itself and not the y sus and z sus boards side boards.
Posted on Aug 26, 2008
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
jerryg50
  • 1691 Answers
SOURCE: Toshiba 42hp66 has sound but no picture
Part of the power supply is in protect mode. There is most likely a short or something failed on one or more of the boards.
The service rep would swap out boards to locate the fault. Then he would leave the new board(s) in the set, and perform any necessary adjustments.
Take the set in for an estimate before approving repairs. There are many times these sets are not worth serving when they are out of warranty.
Jerry G.
Posted on Mar 05, 2010
  • 308 Answers
SOURCE: no picture,sound.Power light comes on (green
Welcome to the world of HD TV sets. Many will last only a few years, regardless of brand. The cheaper ones last only till the warranty runs out and some of those only have a 90 day warranty.
Sounds like a power supply problem but can't be sure without opening it up. The repair cost is almost as much as a replacement set. Many choose not to repair and sell the set to others to try a repair on their own. Options are, pay $200+ for the repair, find another same set with a different problem (broken screen) and use it for parts to fix yours, or sell it as is for someone else to try and fix it. Let me know if you want to sell, I am in Ont also.
Posted on May 04, 2010
SD Tech
  • 14553 Answers
SOURCE: Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Posted on Aug 27, 2012
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
I have a 6 yr old toshiba 50hp16 that is currently not working. I was watching the tv last night...heard a pop...and noticed the picture got darker and the pixilation got very grainy. The television...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 11, 2017 | Toshiba TheaterWide 50HP16 50 in. Plasma...
CANNOT GET GREEN LED ON 2218 TRAXXAS RECEIVER
Hi I am having problems with my 4x4 slash 1/10 scale
When I turn on the vxl-3 and that turns green but the traxxas link goes red for 3-4 sec then starts blinking red can anyone help please
Jul 07, 2012 | Traxxas Link 2.4 Ghz 5 Channel Receiver...
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
Turn on benq pb6200 with new bulb all I get is humming and no led
same problem here. checked fuse, mainboard seems ok. nothing looked blown.
Jul 15, 2010 | BenQ PB6200 Multimedia Projector
I was playing music off PS3 HDD when we had a power cut for approx 0.5sec. Surge/spike protecter was fitted to power source, but no power back up was fitted. Error msg was on screen saying to turn off PS3...
This is a processor error. There is no way to get to the restore screen when you have the yellow light issue. Try CPR in NYC. They usually have a 1-3 day turnaround time, and are pretty cost effective. You can easily ship them your unit. They are faster and cheaper than Sony!
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
37PF5320/10
Hello, I would advise as I do not know all the specifics to try to give the T.V. a signal from a cable box or dvd player. Then I would unplug the T.V. for about 5 minutes and then plug it back in and try to turn it on. Most newer televisions will have a One Year warranty included at the time of purchase so if all else fails, you maybe able to get a warranty replacement.
Jun 02, 2009 | Philips 32PF7320A 32 in. LCD Television
Toshiba 37RV635DB Regza 37-inch Widescreen Full HD 1080p LCD TV w Logo
162 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
