posted by russman on Sep 09, 2007
i just installed the samsumg SH-162L and it is playing DVDs with no sound. i have checked all the settings and everything looks normal.
Solution #1
posted on Jan 10, 2008
i am having the same problem and i cant seem to figure out whats wrong and its not the back of the pc
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 20, 2007
HEADPHONES AND SPEAKERS
Hi There Try this,
CONNECTION
Check your connections on Rear part of your PC. Lime is for Sound Out
usually a speaker, Pink is for Mic, Blue for Audio Input.
VOLUME
Try Adjusting the vlume on your PC first. Check the volume on the
Headphone too if there is one.
CLEANING
Using a dump clothe. Wipe the plugs with a twisting motion.
WIRELESS\BLUETOOTH
Check your battery if it is drained. Try replacing them with a new one
or charge them if they are rechargables.
If all fails then You may have a Sound Card problem. Using a spare
Speaker or Headphone check it if it works. If its not then its
Defective and needs replacement. If its working then your Speakers or
Headphones are defective. Try fixing them by cleaning or checking the
Continuity of its cables using a analog Multi tester.
Hope This helps
If you are having trouble with Newly bought items then return them and
demand a replacement or a refund! You may have purchased a
reconditioned\repaired\factory defect product.
Hi There Try this,
CONNECTION
VOLUME
CLEANING
WIRELESS\BLUETOOTH
Hope This helps
Suggest a new solution for this problem
Post a New problem for Samsung DVD RW Burner
Email this problem
Email this problem
Can you Help with these CD and DVD Burners problems?
Samsung (SH-S162L/BEBN) DVD RW Burner
Samsung SH-S202J
Samsung SH-S202J
Where do I find a driver for... Answer This...
SH-S202 wont read disks
Hey you commented on my post... Answer This...
problem during burning
the problem is a very peculiar... Answer This...
My dvd player wont play dvd's
i got the Samsung DVD rw burner... Answer This...
Repair Service
Find CD and DVD Burner Repairman Near You:
