How to add external rca jacks to the output
To connect your audio receiver to your Proview 3200 flat screen TV, you can use RCA cables. Here are the steps:
Locate the RCA jacks on your TV and audio receiver. One jack is white, and the other is red.
Plug the white RCA cable into the white jack on the TV and the red RCA cable into the red jack. Reversing them will cause the stereo signal from the TV to be incorrect.
Take the other end of the RCA cables and plug the white and red ends into an available RCA input on the back of your audio receiver.
If your TV doesn't have RCA jacks, you can use a digital-to-analog audio converter to connect your TV to a 5.1 audio system that has only RCA inputs 1. You can follow these steps:
Unbox the digital-to-analog converter.
Connect the optical cable to the converter.
Connect the RCA cable to the converter.
Connect the other end of the RCA cable to an available corresponding analog audio input on your audio receiver
