Question about RCA F25216BC 25" TV
Using a VCR with it.
Hi. I just got a used RCA. No manual of course. I have the cable connected to the VCR, but can't figure out what station to put it on to see the movie. The usual 2, 3, 4 don't work...
  • RealRock Sep 09, 2007
    Thanks. The TV only has a coaxil port, no A/V ports. I did get the VCR working, but now can't get the DVD player to play through the VCR... Thanks for your advice!
    Brigadier General:
  • 6,966 Answers
Hi, Based on your post/description, a common installation/connection would be: 1. Ant/Cable in to the RF INput of the VCR (this is assuming that your cable TV is cable/F output and not the audio/video RCA output); 2. A short RG59 cable with F connectors at both ends should connect RF OUT of VCR to ANT/CABLE IN of TV. 3. With the VCR off, the cable would connect automatically to the TV and channel selection is thru your TV. 4. With the VCR on, The TV must be set to either 3 or 4, channel selection may be done on the VCR, TV programs can be recorded, video tapes can be played. A variation: Another would be to use the Audio/Video OUTput of the VCR to the Audio/Video INput of the TV (assuming it's got one). The TV must be set to Video to watch cable, VCR. Channel selection would be thru the VCR. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Posted on Sep 09, 2007
  • Louie  Role
    Louie Role Sep 09, 2007
    Hi again,
    Audio/Video OUTput of the DVD Player to the Audio/Video INput of the VCR. The VCR must be set to Video, TV to either 3 or 4.
SOURCE:
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
Feb 06, 2011 | Computers & Internet
I have a panasonic pv 9451- is there a way to reset the auto programming for the channels? can i reset the vcr programmed information entirelyu and start anew?i think i programmed out channel 3 which is...
Should be able to use the remote to access the VCR menu, and setup the auto programming. If not automatically, then you'll have to do each channel manually. Just check all your options in the menu.
Usually all vcr's have the option of channel 3 or 4.
Apr 14, 2010 | Panasonic PV-9451 VHS VCR
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
[email protected]
Mar 02, 2009 | Daewoo DV-T47N VCR
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Denon ASD-3w ipod dock not being recognized by denon 3808
I successfully connected the ASD-3W to the Denon 3808CI using the supplied AV/Control cables (dock control, L & R audio, S-video). I used the video and audio input connectors marked VCR (iPod) on the 3808CI and used the default settings. I used the connector marked Dock Control for the control cable. These VCR (iPod) connectors are different than the input connectors marked VCR. I turned the source selector to VCR/iPod Stereo and operated the GUI using the ASD-3W remote control. I was able to play music and video.
Nov 16, 2008 | Denon ASD3W IPod Networking Dock Docking...
I cannot record a show onto a blank vhs tape in my vcr??
Initially, pls verify that the coaxial cable is connected to the ANT/Cable/RF IN of the VCR. Thereafter the built-in tuner of the VCR would be used to select the desired channel to be recorded. The VCR in turn maybe connected two (2) ways to the TV:
  • Audio/Video using yellow, red & white RCA cables/connectors using AV1 or Video1;
  • RF patch cord from RF OUT of VCR to ANT/Cable/RF IN of TV using either Channels 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Televison & Video
Vcr taping using rca
Connect the VCR's audio/video outputs to the TV's audio/video inputs. These are the red,white,yellow connectors. get the same colored type cables and it is real easy. Switch the TV to the corresponding input selection. Of course, the signal source needs to be connected to the VCR's input
Dec 30, 2007 | Televison & Video
How to hook up a DVD player
Go to this link; http://www.amazon.com/RCA-32-Stereo-TV-F32450/dp/B00006HMDB and a short way down under "Product Details" there is a link to the product manual page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know. Please post again if you still have trouble; Hope it helps :)
Mar 29, 2007 | RCA F32450 32" TV
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Televison & Video Logo
141 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
