Sounds like DRL sensor gone bad, it does not recognize day and night.
SOURCE: headlights wont come on and bright lights won't stay on hold bright light switch and blower works
I had the same problem. The solution is simple; the ignition switch needs to be replaced. This is an easy do-it-yourself project. Here are instructions:
http://forums.vwvortex.com/zerothread?id=2532481
Check for a switch on ebay, they are about $15. After 10 years they wear out.
SOURCE: only high beamheadlampswork.fusesok
If the other solutions did not work, may be problem in combination switch, located in steering column on lever for headlights.
SOURCE: 2007 mercury milan V6 Car wont start. Jumped it
Remove the lugs at the battery. Clean the posts and the lugs - then reconnect. Your battery won't charge (and the jumpers won't work) largely because of a film on the + post and lug. If you live in a hot summer area, (Arizona) the problem is especially troublesome.
SOURCE: 2005 suzuki forenza My car will not start up.
Check if the kill switch is engaged. Check for faulty starter solenoid or disconnected solenoid wire. Check for defective ignition switch. Check for defective starter motor.
SOURCE: the car won't start; lights,
Check the starter and the starter relay or fuse. A client of mines car was doing the same thing, it ended up being two issues, the starter not working anymore, and a relay that was bad. If I am not mistaken everything should be labeled in the fuse box under the hood and will tell you where the fuse/ relay is for your vehicle
