Question about Maytag MSD2756G Side by Side Refrigerator
Whirlpool ED5VHGXMB10 side by side
Freezer side has lots of frost and ice where it shouldn't be. There is also ice in the vents. Refrigerator side isn't getting cold.
WATER FILTER CHANGED WATER NOT COMING BUT ICE IS COMING
Posted on Aug 01, 2009
I had the same problem, and had to replace the temp regulator. It is located on the refrigerator side, by the water filter. It took me 15 to 20 minutes to replace it.
Posted on Dec 28, 2007
In the food side of my model number ED5NHAXN001 THERE IS FROZEN ICE ON VENT
For now I want you to look at the rear wall of the freezer and see if a layer of frost is building up. Also be aware of any temperature changes taking place on either side of your refrigerator that may indicate a defrost failure. The frost buildup around the vent may be temporary and caused by a door that was not shut properly. I would ask that you check your door seals carefully to insure the doors seal when closed. Small leaks around the door seals will draw warm moist air from inside the home and cause frost buildup like what you are seeing and also cause your refrigerator to run all the time. For now try removing the frost buildup with a hair drier. I will be here if you have questions, Thanks Sea Breeze
Jan 30, 2013 | Whirlpool Refrigerators
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Top part of refrigerator cooling but not the bottom; please help
Defrost the freezer completely. Use boiled water in a pot to make it faster. Frost built up inside the freezer is blocking the vent that lets cold air in the fridge. Good luck
Feb 11, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The things in the freezer are not frozen and there is ice in the milk in the refrigerator. It a 6 year old Whirlpool side by side.
You possibly have a 2 part problem. Do a 12 defrost and make sure the product in the fridge is not near the auger (cold inlet vent into the fridge). Fridge gets its frost from the freezer compartment.
Nov 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Side by Side: Freezer freezes refrig doesn't cool.
check for a blockage. There is only one cooling section, divided by airflow for freezer / fridge.
Perhaps something sticky is in the vents, or the freezer section has poor airflow, resulting in ice formation.
Unplug the unit for several hours, clean out vents, and make sure freezer section has good airflow from the vents.
Aug 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
No air flow to refrigerator section
hi thanks for the question yes lots of times i would check the fan motor in freezer you should be able to hear the fan going with the freezer door open if not replace the fan motor in freezer and also check for frost build up in freezer thanks the appliance doc
Aug 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag MSD2756G Side by Side Refrigerator Logo
792 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
