Question about Microsoft - MN-730 - 54Mbps 802.11g Wireless PCI Adapter (TGM171624RN)
Microsoft Wireless G MN730
Where on the internet can I get updates for the WIRELESS MN730?
    Scholar:
  • 47 Answers
Try http://support.microsoft.com/kb/814445
Posted on Sep 09, 2007
SOURCE:
Cant connect to xbox live
What you need:A high-speed Internet connection such as cable A router, gateway, or wireless access point (WAP) that is compatible with Xbox LIVE. An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only) Instructions: On your console, go to My Xbox, and then select System Settings. Select Network Settings. Select the name of your wireless network. Enter your wireless network password. Select Yes if you are prompted to update your console software. When you successfully connect to Xbox LIVE, your screen will look like this:
Jul 25, 2011 | Microsoft Wireless Network Adapter Xbox...
Tip
How to connect your Xbox 360 to the internet
In this guide I will go over how to connect your Xbox 360 to the internet either via wired or wireless connection.
Wireless Connection
*For a wireless connection you need a wireless access point(router) and either a Xbox with built in wifi adapter or purchase a xbox wireless adapter*
-Turn on your xbox and go to "My Xbox" then go to "System Settings"
-Select "Network Settings"
-Select the name of your wireless network.
If you do not see your network, select "Advanced options" then select "Specify unlisted Network" then enter your network name.
Enter your wireless network security key. It may prompt you to update your console, select yes.
Wired Connection
*For a wired connection you need to use an Ethernet cable and plug one end into the back of your xbox and the other end into your router or cable modem.*
-Select "Test Xbox Live Connection", afterwards it may prompt you to update your console, select yes.
Now, you are connected to the internet and can enjoy xbox live.
Regards,
G33k
on May 12, 2011 | Microsoft Xbox 360 Console
I have F5D7234-4V1 with insight internet connection and i have win-xp laptop , ERROR MESSAGE - (windows cannot configured wireless ) tell me what to do - But unable to start WZC on my computer
If you want to use Windows Wireless Zero Configuration to manage the wireless network, you will need to have Windows XP with service pack 2 as a minimum.
With Windows XP and SP2, you will need a Microsoft update for WPA2 that can be obtained from:
http://support.microsoft.com/kb/893357/en-us
After installation you will need to use the Windows Zero Config wireless configuration in the control panel to configure the adapter. WPA2 should now be available and work correctly.
Windows XP with Service Pack 3 and Windows Vista offer support for WPA2 without additional updates.
Nov 04, 2010 | Belkin F5D7234-4 Router
Quick instruction to install leeds asi/66887 wireless mouse
You need installation disc, if you have lost the CD, than go to this site Driver Update Software for XP Vista 7 8 and download their update tool. I hope I helped.
Micky
Feb 12, 2010 | Microsoft Wireless Notebook Optical Mouse...
I had XP on the amilo pro, connected to talk talk wireless, no problems, all OK. Put a new XP on it, not able to connect to wireless, as the wireless butoon not turning wireless on, and LED also off for...
Open the Network settings and show available networks. Select the available network and when asked to insert the Modem Authorization data, type in the WiFi password.
The password should be on a label attached to the modem.
Jan 16, 2018 | Fujitsu Siemens AMILO Pro V2000 Notebook
Will not connect to internet,wireless or cable,
For $200, they probably will be:
(1) backing-up all your data files;
(2) using the CD-ROMs that came with your computer, reinstalling Windows
(3) applying all the Windows Update and Microsoft Update security-updates
(4) reloading free software (Adobe Flash, Adobe Reader)
(5) installing some anti-virus software
(6) restoring your data from a backup
So, pay the $200, or do it yourself.
Oct 21, 2009 | Gateway Computers & Internet
Same problem hp wireless assitant not working
Troubleshoot your wireless network with HP mobile and wireless solutions
update (flash) the Bios
install all the Nvidia updates (chipset and Video)
Audio
Modem (only if you use this to access the internet or possibly will in the future - ie on vacation)
Hp software updates (Quick Launch and Q/L Critical update)
Essential Vista updates (these are the ONLY Microsoft related updates I installed)
Finally the Wireless Driver update (in my case the Broadcom W/L Card)
and the little blue light came back !!! Even better was that it turns off when it's supposed to and back on when it is supposed to.
Wireless Works - I tested by connecting to multiple different networks for stability (just go to a couple of different MacDonald's, Starbuck's and Safeway stores to try this if you cannot find available networks in your neighbourhood) You don't have to connect to them, just get to the point where it checks for the passcode/network key and you've successfully communicated with the router and this will count as connecting to a wireless device.
i have TURNED OFF ALL WINDOWS UPDATES, this is important because it is an update to the operating system (Windows Vista) that is causing the problems in the first place. (Not a conspiracy between HP/Compaq and Microsoft to cause you to pay for expensive parts that don't fix the problem or go out and pay for a full copy of Windows Vista and have it installed professionally)
I used to work for the retailer that sold me this laptop for my step daughter (and HP authourized repair centre) and now i work for a Network and Systems Support HelpDesk so i can safely say that you don't need to fall for the warning from Microsoft about needing to keep your operating system constantly updated because if you connect to a Wireless network in the fireplace you are behind a firewall and thus protected by the nasty little things floating around out there. If you are worried about the security concerns about your browser (internet explorer) the download Firefox - it is built on a much safer code and is regularily updated as well and won't leave you open to installing the nasty microsoft code that breaks your laptop
Jul 22, 2009 | Microsoft Windows Vista Home Premium...
My Compaq laptop Presario F700 series, Vista and AMD64AnthlON X2
Microsoft security updates have disabled wireless cards in the past, preventing systems that connect via wireless card to connect. One way around this is to revert to a point before the update or uninstall the particular update that is causing the problem through "Add Remove Programs" and usually within a few days Microsoft will have an update with a fix available.
Though this is the first I've heard of such a problem recently, it's not unheard of.
Apr 19, 2009 | HP Compaq Presario F730US Notebook
I recently got an ipod and wanted to download itunes , but i couldn't because i need it service pack 2 updated. So i went to microsoft updates and ran all the updates that i haven't done since i got my...
How can you go to microsoft updates if you cannot connect to the internet via wireless or directly connected to the modem as these are the only two ways you can get internet. So, do you have internet? If you do go to this website to download Service Pack 3, as this is the newest Service Pack, here is the link: http://www.microsoft.com/windows/products/windowsxp/sp3/default.mspx . Hole I helped.
Jan 28, 2009 | Dell Inspiron 8600 Notebook
Netgear wn111 installation problem. " MICROSOFT WINDOWS XP UPDATE REQUIRED" before this application can proceed, you must update the Microsoft windows xp software on this computer. XP HOT FIX KB822603 The...
You are very limited here, but it's not impossible. Have you tried getting to a wired connection temporarily? A long way around would be to reinstall Win XP with a disc that includes the update. A word of warning though, the fix you have described (KB822603) is already included in SP2 on Win XP...SO... while you are connected to the wired internet connection, you may have to get an update for the driver of the netgear wireless wn111 hardware as well.
I hope this helps.
Jan 10, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Computers & Internet Logo
603 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
