My daughter bought one of these and cannot use it. Dew detected then shut down. She gave it to me to try to fix. I need a schematic for this palmcorder. Thankyou, Leo
Comment by Guest, posted on Apr 05, 2008
dew detected
Comment by Guest, posted on Dec 01, 2007
Same problem same solution take the battery off without turning off the camera and voila!
Best Solution
posted on Nov 11, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
"Solution" suggested by mace biglow really works !!! After couple of hits the "Dew detected" message went away. Thanks
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Dew detected on DV-203:
Solution #2
posted on Sep 27, 2007
Guest
Thanks Mace Bigelow. Could not understand why dew detected suddenly showed up on the screen. This camcorder was not in any place to collect dew. Took out the battery as you suggested and gave it a couple of shots. Camcorder is now working fine. Thanks
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works!
When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
incredible the palm trick works for me aswell thank you very much
Comment by kennythewise, posted on Nov 23, 2007
ok the real problem is the connectors under the camera with the vibration they will get loose with time to fix this u must remove the base of the camera and carefully remove the 3 of them clean them with alcool and put them back in place u can put a small tape on them just to avoid the same problem to happen again
Well I'll be! Giving it a good smack got mine working too. I'm afraid this might be a recurrent problem though. My Dew Detected issue lasted all of 2005, then one day went away sometime in 2006, but then came back again in early 2007 and was here to stay. Thanks to Mace I have a functioning camera again. Though if the Dew thing comes back, the camera may get more than a little smack!
if this is always happen to your camera and then try to warm the camera using a hair blower you should open the lid cover of the mechanical.......... turns off the camera and unplugged the ac adaptor..if you using the battery take it out ... then place your hand to the mechanical to sense the heat of the camera when you using the hair blower and when you feel too hot then stop the blower.... doing this must not exceed 15 second...... then wait at least 1 minute to cold down the camera and put the adaptor or the battery then power on the camera.... if you doing this and nothing happen....i suggest you to go to the service center for replacing the dew sensor....
