Kenwood UD-505 speaker problem
I have a Kenwood stereo of model number UD-505. I have attached two main speakers to the unit, as instructed in the owner's manual. I have then attached a centre speaker to the surround speakers port The speaker is hooked up to my TV through an RCA connection. I've been having a problem where whichever mode I choose, Dolby Surround, Pro Logic or 3-Speaker, I can't get the speakers to all work together. The large speakers work and the small centre speaker doesn't or the other way around. This speaker system in about 10 years old, so I haven't had any luck finding help anywhere else. Fingers crossed and thanks in advance.
4 Suggested Answers
SOURCE:
simplemitch
  • 752 Answers
SOURCE: TV to Home theatre
The center speaker shouldn't be on the surround outputs it should be on the Center output. The surround outputs are for the rear speakers.
Posted on Sep 13, 2007
electrepairu
  • 195 Answers
SOURCE: Can't get my Kenwood VR715 receiver to go into the Select a speaker system to see if speakers are turned on. Followed manual instructions and can't get in. Any Suggestions.
Try resetting the unit by unplugging the unit from the wall, then plugging it in again WHILST holding the power on/standby button in. This should reset the system. If not:
[email protected] or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Posted on Jan 07, 2017
SOURCE: Want to use my current speakers with a new surround sound system. Current system is 5.1 channels, rated at 100w per channel @ 8. Ohms. New System is rated 145watts, 5.2 channels at 6 Ohms. Will b ok?
Hi Ronald.
8 Ohm speakers will work just fine as replacements for the
6 ohm speakers. When fitting speakers you need to consider
The power handling capability. The impedance and the frequencies
involved. Power handling is expressed in wattage ie 100W.
Unfortunately this can be expressed in rms, max or peak music. The rms value (root mean square) is the only really relevant figure as this is the continuose handling power at 1 KHz. The impedance
is the resistance that the amp sees but is not a dc resistance and
varies with frequency. The lower the impedance the more power
will be drawn from the amp. In the event of a short circuit across
the speaker the amp will try to deliver infinite power into an infinitly
small load in an infinitesimal amount of time and will self destruct.
Using an 8 Ohm speaker draws less power than a 6 Ohm speaker.
Connecting speakers in parallel; results in the impedance beingreduced. For example two 8 Ohm speakers in parallel will result
in a 4 Ohm impedance load but in series will be 16 Ohms.
Incidentally the the .1 (5.1) is the sub woofer which only has
to handle the bass frequencies, a small percentage of the
amplifiers overall frequency response..
Connect your speakers and then power up the amp last
after double checking there are no shorts on the speaker
cables.
All the very best from Vintie.
Posted on Jan 08, 2017
How to hook up speakers
Dennis, Check the attached links diagrams,instruction and guides for hooking up speakers. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Connect Stereo System Stereo Barn
How to Set Up Your Speakers with Receiver or Amplifier
amplifier wiring diagram Google Search
speaker wiring diagram Google Search
Aug 16, 2016 | Kenwood Audio Players & Recorders
Kenwood A722L no sound and volume led blinking
This could be due to a faulty speaker relay (if your unit uses one). Normally, the unit will "wait" a couple of seconds after you turn the unit on. Then you will hear a "click" and the sound will begin coming through the speakers. If the relay is faulty, it would cause the problem you describe.
Aug 01, 2014 | Kenwood Audio Players & Recorders
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
I have remote RC 505 -- I'm new user - unit went into protect mode and it doesn't respond to remote. With unit face closed I don't know where to find model designation to see correct...
if the unit is in protect mode then there may be the possibility that the speaker wires may have a short circuit in them or that the amplifier section may be damaged....you can remove the radio from it's sleeve and check the wiring behind the unit...this also would have to be done to see the model number and serial number...it should be on either the top or bottom of the unit...the speaker wires for this unit are the white, gray, green, and violet...each with another of the same color but has a black stripe in it...the black stripe is the negative side of the speaker wire....you can disconnect these wires, then turn on the unit to see if it comes out of protect mode...if it does, then there is either a bad wire somewhere in the car or a bad speaker...if the unit stays in the protect mode, then you will have to take the unit in for repair, as this indicates a circuit failure
May 19, 2011 | Kenwood Sirius KDC-MP819 CD Player
Kenwood kdc-mp239 car stereo overheating
Did you change the speakers, usually this happen because of the Ohms. Let me explain you, The factory radios are usally 8 Ohms and must of the aftermarket speakers are 4 Ohms or less so if you put 4 Ohms in a radio designed to work with 8 Ohms of coures is going to get hot first and them you burn it out.
Jan 04, 2010 | Car Audio & Video
I have a jvc home stereo model number CA-HXC6 i have had it for a few years its on protect mode and i cant get it off dont know how it cuts off
Turn off power, unplugg unit, very carefully check speaker wire connections making sure no wires are touching each other or the back of the unit same at speakers connections. Also check speakers. Blown drivers can short terminals internally. This is the most likely problem. Remove the short, unit will come back on
Dec 21, 2008 | Bose 901 VI Main / Stereo Speaker
I need to install a kenwood cd player into my 2001 ford explorer step by step
goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
Insert wiring harness into the stock wiring
attach fascia in regards to its packaged instructions.
Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
Insert stereo into new cage and voila nice new stereo.
Nov 27, 2008 | Kenwood Car Audio & Video
TV to Home theatre
Sep 09, 2007 | Audio Players & Recorders
87 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
