Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
This fridge has been setting for a few days unplugged. I plugged it in and the temp control indicators for the refrigerator and freezer both stay dark and only blink "0" about every 15 seconds, then go dark again. I have tried unplugging and re-plugging. This didn't help. The freezer is getting cold but the refrigerator seems to be warm. This is 2+ hours after plugging it in. Any ideas? Reset procedure? Thanks to anyone - my food is getting warm.... Wavester
  • Anonymous Mar 16, 2014
    I've had my fridge sitting in storage in freezing temps. Tried to plug it in and nothing is working. I am getting power as the light comes on. Any suggestions?
Set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Posted on Sep 28, 2007
SOURCE:
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica Refrifgerator- Not cooling
its either the ptc overload on the units compressor is bad and is easily replaced by unplugging the old and replacing with a new replacement,the only other thing it may be is the cold control for setting the temp of the freezer/refrigerator,but normally these don't go out
May 15, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica Refrigerator Displays OFF PSS29NGNAWW
Sadly i would say the board is malfunctioning and needs replacement. There is nothing in the fridge/ freezer that if malfunctions can cause that.
Sep 21, 2009 | GE Profile PCF25PGW Side by Side...
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
409 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
