Question about Digi-Tech DOD-Digitech 231 - 31 Band Per Side Equalizer Home Equalizer
FULL BAND OF AUDIO NOT CLEAR
WHENEVER A CD IS BEING PLAYED I CANNOT HEAR CLEARLY THE LEAD SINGER, THE BACKUP SINGERS AND THE INSTRUMENTS ARE CLEAR.
    Problem Solver:
  • 5 Answers
If you have set the EQ curve to the typical "disco smile" ( where the curve looks like a smiling mouth) that everyone who is inexperienced seems to do, then you have turned down the midrange area. Human vocals appear between 200hz to about 5kHz. If the vocals are clear when the unit is in bypass mode, then you are not operating the eq properly. If they are not clear when the EQ is bypassed, you have another problem. The best way to run an EQ is to leave most of it flat across the entire range, at zero gain and CUT only the stuff that is annoying, or caused by your room or speaker limitations. Try this first, before assuming you have a hardware fault.
Posted on Nov 23, 2007
  • Gregg Sheehan Nov 23, 2007
    You may also have something out of phase, even your speakers. Generally, lead vocals are mixed, panned to center, to appear in equal quantities in both the left and right speakers. This is not the case with older recordings like the Beatles where the vocals were often hard-panned left or right. Vocals centered makes it also better for radio play.
How do you set a 10 band equalizer so the sound is nice
The equalizer selectively amplifies certain frequency bands. If you know the frequency band the band can be adjusted. I took a song and boosted the bass singer's voice by jacking up that band.
Oct 06, 2014 | Audio Players & Recorders
Is there a place to download the cd that came with the singer futura CE-100 embroidery machine. I don't think I should have to pay for something that came with the machine.
Oh, I agree with you. Unfortunately, there isn't a place to download the silly thing. I searched all over the place when I lost mine and just couldn't find anything other than the fact I had to go back to Singer to replace it.
I suggest STRONGLY that you be sure to do a backup on a portable harddrive/CD/something similar of the CD when you get it. Be aware that you should do it as a system backup of your computer, because the program will ask you to insert the CD if you simply try to do a reinstall of the program. That's why it doesn't do any good for anyone to upload it to the web for people-the program is set to check for an original CD from Singer before it will proceed.
Mar 25, 2011 | Singer CE-100 Futura Computerized Sewing...
Hi, i would like to buy some sharp microphones, two for lead singers and 6 for musician. can you give me some advice on what types i should get?
Hello
microphones broadly fall into 2 distinct types
  1. Condenser - requires a power source either a battery inside the microphone itself or remote 'phantom power' usually provided from a p.a. mixer.
  2. Dynamic - do not require a power source. Most famous of all is the Shure SM57 (instrument / vocals) and SM58 (lead vocals) used by many musicians and singers around the world.
Condenser microphones are used extensively in recording studios because they are very sensitive and have a better range than dynamic mics. However they are a bit fragile and good ones are expensive. There are plenty of cheap condenser microphones about but they give a rather tinny sound.
If you want the microphones for general band work, especially gigging you will get better value for money with dynamic microphones. These are much less sensitive that condenser mics and are intended for close up work - no more than a few inches from the mouth of the singer (use a pop shield to prevent unwanted noises) or hung close in to an instrument.
There are also 3 different pick-up patterns for microphones. Which ones you go for will depend on the use for which they are intended.
  1. Cardoid - cone shaped directional pick up pattern. These will only pick up sound from in front of the microphone in a cone shape of about 60 degrees. Suitable for general vocals and instruments. Good resistance to feedback. To effectively mic-up a big instrument like a piano you may need to use more than one mic.
  2. Hyper Cardoid - as above but with a much narrower pic-up sone - a cone of about 30 degrees. These are very good for lead vocals as you can drive them a bit harder without risk of feedback or picking up other instrument sounds on the stage (particularly useful if you have a singer who plays an a loud acoustic instrument or a keyboard with built in speakers). THese are okay for using to mike-up an instrument where the sound comes from a small fixed point (saxophone, violin, trumpet, acoustic guitar - provided that the musician stands still) but not much good for larger instruments like pianos or harps. They are also good for mike-ing guitar amps, but only if they don't have a separate tweeter.
  3. Omni-Directional . These will pick up sound from all around. Whilst they can be good for picking up large acoustic instruments or choirs they are very prone to feedback and are not really suitable for public address purposes.
Don't be tempted to buy cheap microphones with permanently fitted cables, especially ones with a standard 6mm jack-plug. Always go for mikes with a balanced (3 pin xlr) cable as they do not pick up as much radio interference on the cable (but only provided your mixer/amp also has balanced inputs too).
Although many professionals swear by the Shure SM57 and SM58 mics mentioned above I personally prefer the AKG D55 a hyper-cardoid which has a longer pick-up range and higher output than the Shures (useful if musicians or singers hang back a bit from the mic) and usually slightly cheaper too. It is really good for lead vocals but makes a good instrument mic too with a nice crisp but warm sound across the frequency range.
For larger instruments, or two backing singers sharing a mike, I use the standard cardoid version of the same AKG (but I'm afraid I can't remember the model number now).
If you want to mike up drums that is another subject all together.
Jan 31, 2011 | Sharp Audio Players & Recorders
Sound problems
panasonic sa th-440 f61
Aug 18, 2009 | Venturer STS152 System
The audio
its probably the headphones: on of the sides has died. try different headphones. maybe a new brand would help too. DONT buy expensive earbuds, they break too easily. and dont wiorry, this happens to me all the time because i play with the wire when im listening..
Apr 03, 2009 | Audio Players & Recorders
Have stopped getting voice audio.
Reinstall the Audio Device driver .
Mar 31, 2009 | Audio Players & Recorders
VOICE
make sure the surround is off. Also, there is a setting on the remote that changes the volume on certain speakers. I think its 'CH.SELECT'. Just lower the front speaker and raise the center channel.
Apr 17, 2008 | Panasonic SC-AK78 CD Shelf System
GH3 - no sound from the band/singers!!??!!
I think the problem is that the sound options for the game is turned off or its just set to low. So if you go to options on the main menu you may be able to change the sound options
good luck
Mar 20, 2008 | Sony PlayStation 2 (PS2) Console
Open Questions:
91 people viewed this question
Top Digi-Tech Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Digi-Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
