Question about JVC GR-D270 Mini DV Digital Camcorder
I can't copy my videos to my computer/CD's.
I'm using Windows XP, and have firewire connection. I've tried Movie Maker and nero plus some others. They see the firewire but nothing sees my camera. I tried contacting JVC but they are no help, they don't even respond. I tried downloading drivers and that did not help. What do I need to do??? Totaly frusterated!
  • Anonymous Jan 08, 2008
    HOW I CAN SEE MY VIDEO RECORDED ON GR-D270 ON PC
A follw-up response to my initial reply.
We eventually found the problem to this issue, without the need to purchase a new firewire cable and the only way that our connection is established is:
Step 1 - Plug the firewire cable into the camcorder and computer (before switching the pc on)
Step 2 - Switch the camcorder into the 'on' position (before switching the pc on)
Step 3 - Boot up the pc.
Step 4 - Once the pc is loaded, open the editing software package and the connection is established.
It's worth a try and may solve your issue.
Posted on Nov 17, 2007
We too are having this problem. When we open our editing software, on the pc, to communicate with the camera, the camera responds with the pc, although there is no picture image showing on the pc and as a result we can't capture any video footage.
We are planning to try a different firewire cable, to assess whether that is the issue.
Posted on Nov 15, 2007
SOURCE:
I have a sharp camcorder that will not play though my toshiba laptop, I have windows7 and the cd that came with the viewcam z model num. VL-Z7S is for windows XP is DVC USB Driver ver.1.1
You have the CD and now you don't have the compatible CD for windows 7,
now all you have to do is to acquire your videos through (MOVIE MAKER SOFTWARE)
1.Microsoft recommends the free download of the latest Windows Live Suite, which includes Windows Live Movie Maker (WLMM) for Vista and Windows 7 (XP doesn't support WLMM). That gets you the newest version, but one considerably slimmed down in features from MM2.1 in XP or MM6 in Vista. It's good for quickly and easily making a video and uploading to YouTube, but not for anything close to the kinds of serious editing you can do with classic versions of Movie Maker.
Experienced users will want to continue with what they've become accustomed to. It turns out the special Vista edition MM2.6 downloads, installs and works fine on Windows 7. It was produced by Microsoft to help those who were having problems with the version 6.0 in Vista. Although stripped of many features, it's pretty much aligned with the familiar MM2.1 of Windows XP. MM2.6 is the only classic version of Movie Maker that's a stand-alone download from Microsoft and an easy installation ... get it at:
2. here is Movie Maker 2.6
MM2.6 has the features to fully edit and produce a video, but it doesn't have the importing feature of MM2.1. For that, you can use the import wizard in the Windows Live Suite. MM2.6 works well with the Pixelan Spice FX6 packages of extras and Wizards, and you can setup other custom effects and transitions to work with it.
I've copied MM1 and MM2.1 from my XP system and MM6 from my Vista system, registered the DLLs and they are working well. But I haven't yet added many of the thousands of extra 3rd party special effects and transitions that are on my XP and Vista computers.
It turns out installing MM2.6 also resolved some Issues I experienced with MM2.1 in Windows 7. It's not surprising as they are very similar with one made for XP and the other for Vista. The Windows 7 system is closer to Vista.
3.Now Importing a Video
In addition to the newest version of Movie Maker, the Windows Live Suite includes a video import wizard that works with a mini-DV or digital8 camcorder connected by FireWire. MM1 and MM2.1 in Windows 7 also capture video from my mini-DV camcorder, when connected by FireWire.
Imported video clips can be browsed in the folders of the Windows Live Photo Gallery or imported into the collections of the classic versions of Movie Maker.
Starting with no version of Movie Maker in Windows 7, I'm now running with five of them.
hope this helps you do vote if it helps you in this regard
Apr 03, 2011 | Sharp VL-Z7S Mini DV Digital Camcorder
I DON`T HAVE A CD DRIVER FOR COPY OF VEDIOS TO COMPUTER
If your camera uses firewire connection it seldom comes with a C.D. just pluging in the camera to your P.C should activate the program it requiers.
One needs a movie maker program to copy movies from the camera on to the P.C.Try windows movie maker. If not try to download one from th web
Mar 12, 2010 | Panasonic NV-VZ55 Camcorder
PV-DV103 will not connect to pc via Firewire - Windows Movie makr
ur COMP. graphic is low. ur camera need capturing card on PC u can edit ur pic in movie maker
Mar 17, 2009 | Panasonic PV-DV103 Mini DV Digital...
What do I need to transfer video from jvc cam to my laptop
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
You can then use Move Maker to any disc burning software like Nero to create the movie disks.
Jan 04, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
Connecting dcr-hc30 handycam to computer
i have an idea for that. try to use windows xp OS and download the driver that ill provide for you. after you download install it to your pc and plug your device i hope it recognize. if does, upload your video then use any movie maker such as ulead movie maker, nero movie maker, windows movie maker etc.. and save it as any video types that you like such as avi, divx, dvd, vcd, ect.. now you have your videos on your computer. hope that helps!
http://www.sony-asia.com/support/download/1656/product/dcr-hc30/modelfirst?site=hp_en_AP_i
CHARCOIS
Aug 01, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
PV GS39 Win XP Movie Maker
I don't know if Windows XP Movie Maker can detect a firewire based video camera.
Do you have DVD burning software such as Nero in your computer? That has capture capability to it.
Pinnacle Studio will detect a firewire camera. It is reasonably priced and easy to use. In fact you can control your camcorder from Studio in case you need to rewind or fast forward the tape.
May 14, 2008 | Panasonic PV-GS39 Mini DV Digital...
Sony DCR-HC38E Exporting miniDV video to computer
I had a similar problem with my Sharp camorder.
The preview window on XP simply displays corrupted images.
At the end, I bought a different firewire card and it worked for me.
Good luck.
Alex
New Zealand
Jan 15, 2008 | Cameras
Transfer video into dvd on computer
Well what i did was i got a ati video card that had built in video inputs (and it also had a tunner) plugged the camcorder up to it and recored what was on the camcorder on to the pc (ati came with a utility that made this possible). after the movie was on the PC i recored it to dvd with nero. I think you could also use movie maker that comes with windows xp
Dec 05, 2007 | Canon ZR200 Mini DV Digital Camcorder
USB drivers for panasonic nv-gs11 gc
I have a software for that model.... NV-GS11GC it work only on Window XP,Me,98SE
Dec 04, 2007 | Panasonic NV-GS11gc Mini DV Digital...
CPU not recognizing my camcorder
I hope you are connecting the camera to the Fire wire port of the camera, if not, if you are using a desktop, you require a an addon card called IEEE 1394 firewire card, which you have to install it on your motherboard's PCI slot, then using the firewire cable which you get along with the card should be connected to the card and DV port of the camera, then using the MOVIE MAKER software of windows XP, you can download the video.
Apr 03, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D270 Mini DV Digital Camcorder Logo
124 people viewed this question
Top JVC Video Cameras Experts
Ekse
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
