Question about JVC AV-48P775 48" HDTV
No color there is no red in my tv, where is my converance box in the back of my tv.
  • 3 Answers
You're using YPbPr (Red/Green/Blue Component) cables, right? Make sure you've got them in the right inputs and that the cables are FIRMLY attached. (Sometimes they seem attached even when there's a half-inch or so of space still)
Posted on Sep 09, 2007
SOURCE:
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Can I get the codes to program my RCA converer remmote
go to rca''s website and there will be tabs to walk you thru to get any codes
Apr 26, 2009 | RCA ATSC11 DTV Receiver
Blue converence was intermitten now out on sides
If the IC's say have STK printed on them, then they are the convergence IC' s. should be three of them, replace all 3 , and the burned green coils, sometimes these burn as they supply the volts to the STK's. good luck, be safe..
Mar 11, 2009 | Sony KP-61V45 61" Rear Projection...
Converence
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Aug 09, 2008 | Zenith R56W36 56" Rear Projection...
Red / Green issue when connecting Mits DVD to Mitsubishi TV
Convergence problems, look in menu and find manual conver. and read for more info goto ctechnicians.com
Dec 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Aug 16, 2007 | Zenith R56W36 56" Rear Projection...
Bulbs not working
the big converence ics like SK----- as they go bad your covergence with shift and shift and become unjustable..need to replace them. the bulbs? if your messing with CRTS dont or even try turning the yokes. sometimes it takes me hours and days to put all back right what the customer did....alot of times if you call my shop and said you were working on it Id tell you to call somebody else. good luck
Aug 16, 2007 | Samsung HCM422W 42" Rear Projection...
JVC AV-56WP74
sounds like a power supply7 problem such as a power regulator is bad or maybe the Horizonbtal deflection cu8rcuity is defective. sounds like something if you ask me? should be taken care of by the pros??? Im sorry not being able to assist you better but these sets have hundreds of volts nin them and shoulnt be played with by an unauthoized service company.. Good Luck
May 19, 2006 | JVC AV-56WP74 56" Rear Projection...
JVC AV-48P775 48" HDTV Logo
73 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
