Question about Philips 50P8341 50" Rear Projection Television
Double vision with blue outlines around objects on tv
Everytime we turn on the tv it comes out with double vision to the right of whatever object is on the tv. it looks like there are double people and the second one is blue. please help, what could be the problem???
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
You may need convergence amp replacement. this is a job to be done an experienced tv repair person ..but can usually be done for a few hundred buck$$
Posted on Sep 11, 2007
SOURCE:
E420i-A1 color problems
This is not normal, return the set ASAP
Jan 15, 2013 | Vizio Televison & Video
Tv shows double vision in blue color. how to fix this problem?
This is a problem with your convergence settings found under your tv's menu. its very easily fixed, you just need to open the setting for convergence and use the arrows on your remote to adjust. inproper convergence can cause either a red or blue haze around almost any object displayed on the tv screen
Apr 14, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 20, 2010 | Televison & Video
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blue color on screen
If mostly blue shadow appears around the white objects means the cooling liquied is getting dirty and needs to be replaced.
May 27, 2009 | Philips 46PP9302 46" Rear Projection...
Shadows double vision
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Apr 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
HDTV 1080i or HCM553W blue and yello ora around objects
You are going to have to reconverge your TV. Order a service manual and it has a 20 page set of instructions on how to set up the convergence for the first time with new convergence amplifiers. Once you have done this procedure the "perfect picture" one touch control should be enough to keep it in convergence. You must have the original remote control in order to do the convergence procedure.
Good Luck.
Dan
Oct 23, 2008 | Samsung HCM553W 55" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
