Question about Blaupunkt Lausanne CD31 CD Player
Blaupaunkt lausanne cd31
Hi, im having trouble with my cd player wondering if anyone an help me. it was working fine untill the battery of the car got disconnected. now some digits appear on it and when you try a function it automatically switches off, there is some code at the back of the flip,they are checked numbers im guessing it is the code for it, but ive no idea how to insert it
  • 3 more comments
  • redfelin Nov 08, 2007
    digets displayed and will not respond on any buttons
  • malcolmX Jan 11, 2008
    Hi I have the same problem, after disconnecting from the battery ( to reconnect the arial ) nothing works.... only when I press the menu do I get the time and a view of the disc spinning
  • mcb-j085 Mar 10, 2008
    Disconnected battery and now my lausanne cd31 will only display the time.
  • Anonymous May 08, 2008
    After Three years of use, my lausanne cd31 doesn't respond anymore. When I try to turn it on, I get no response. And when I press the menu button, it only display the time (by the way bad time). Any suggestions ?
  • pink_ice Jan 07, 2009
    I'm also having a similar problem.
    Before Christmas it started to skip on CD's which shouldn't be skipping at all and weren't scratched. I got so fed up with it i just took the front panel off and didn't bother with it again until the New Year. Over the holidays though, my car battery died, and i had to get a new one fitted. Now when i try and use the player the time is just displayed and no buttons work at all.
    Thinking i'm going to have to get a new stereo....
    New Friend:
  • 10 Answers
You need to change scala bulps inside front then you will see on the screen again :)
Posted on Jan 20, 2012
  • nick Sep 25, 2012
    what are scala bulps?
    New Friend:
My display doesn't work at all... but the radio and the cd still works.
Posted on Dec 30, 2009
  • steinarx
    steinarx Jan 20, 2012
    you need to change scala bulps inside front then you will see on the screen again :)
SOURCE:
Where is reset button on blaupunkt san ramo cd31
There is no such button to this set. You have to enter its service mode to do this. It is a semi-skilled work. Contact any service technician. Gopakumar Gopalan Google
Jun 05, 2014 | Blaupunkt San Remo CD31 CD Player
Sometimes i put a CD in and it will start to read it and then come up with CD error, is there any reason for this? Other times it will play it fine until you go to change the CD then you have the same...
Hi, It could be a scratched cd or a dirty lazer inside the unit. Any car wax or pledge works wounders on cd and dvds. And if it's the player you cold look for a lazor head cleaner. It lloks like a cd only it has fine hairs that brush of the lens of the lazer. good luck
http://www.amazon.com/Maxell-DVD-LC-DVD-Lens-Cleaner/dp/B00000JPPI
Oct 31, 2010 | Blaupunkt Lausanne CD31 CD Player
Put in code but could not press enter, entered code but nothing happend so entered it again now its locked
leave it switched on..undisturbed for as long as it takes to automatically reset itself.
If your radio is a BP Lausanne then the code entry instructions are
Blaupunkt Lausanne CD30 Code Entry
Turn on the radio, the display will show 'CODE' followed by '0000'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Finally press the [ station ^ ] button to save.
blank.gif _uacct = "UA-277454-2"; urchinTracker();
May 05, 2010 | Blaupunkt Lausanne CD31 CD Player
CD doesn't work and clock goes back to 0:00 when the car is turned off
i think u got the red and yellow or orange wires turned around
Mar 07, 2010 | Blaupunkt Lausanne CD31 CD Player
2004 cadillac srx cd player jammed
I had the same problem. disconnect the battery cables. then reconnect them. this will reset the cd player and it should relaese all your cd player problems.
this happened twice to me and the above worked fine both times.
Jun 11, 2009 | 2004 Cadillac SRX
Acura TL CD player does not work. Whenever I press the CD butteon it shuts down the stereo. Does anyone have a solution
this happened to my 04 tl. it would stay on for the radio but once i hit the cd it would completely shut down until i turn the car off. i had to take it back to the dealership and they had to have it replaced. if you got the car not too long ago you should take it back since they shouldnt be selling you a car with parts that will fail so soon or if you have a warranty then it should be all good.
Mar 06, 2009 | 2004 Acura TL
Cd/Rw playback CD player in lounge room won't play burned cd's...
Hi.
You need to burn your CDs in Audio format. That means that you cannot just burn your MP3 or WMA files, but you need to use the program which can convert those files to WAV format and write them so that ordinary CD players can reproduce them. Nero is such a program, among others.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Blaupunkt Lausanne CD31 CD Player Logo
793 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
