Question about Dell 942 All-In-One InkJet Printer
It says clear the carrier jam and the press start
  • 4 more comments
  • Jrara Dec 23, 2007
    My 942 printer also says it has a carrier jam and has a grinding sound too. How do I clear a carrier jam? There is no paper in the printer. I did have a sheet of paper stuck and I pulled it out.
  • funmickey26 Dec 26, 2007
    my computer have a carrier jam and i don't know how to fix it
  • MDITTY Jan 02, 2008
    Can someone please help with this "Carrier Jam" issue? When I turn on the printer, the carrier goes from side to side, and loudly hits each side. Then I get the message "clear the carrier jam." Troubleshooting online at Dell says to make sure the cartridge covers are down tightly. I have checked this several time, and is not the cause of the problem.
  • bordino Jun 13, 2008
    My 942 printer displays carrier jam when there is no jam.
    Help
  • annch Aug 17, 2008
    I have the same problem with the cartridge carriers going rapidly from side to side and hearing a horrible grinding problem. Does anyone know if there is such a thing as 'belts' for the carrier that could have been broken? If so are there replacements? My printer has been really good up until this problem.
  • Anonymous Nov 29, 2008
    I have the same problem and decided to try cleaning as much as I could without tearing the printer apart. What I found was:
    1. Dead leaf from small hanging plant that used to be above printer area. Solution, moved the plant.
    2. Still had paper jam message. So kept cleaning rollers and what ever space I could. Discovered that the little drive belt on the front roller was broken. Hence why kept getting paper jam message due to the fact the roller couldn't move.
    Now I am trying to find a parts list to see if can order the part and or if I can find something similar to the tiny belt.
    As an added not I had to use a flashlight to finally discover the broken belt.
Yea i havent been able to print out my homework for like 2 weeks. i say dell printers suck. they should recall them. My printer just likes to turn on and off, thats it!
Posted on Jan 03, 2008
I know this sounds stupid, but I read somewhere, on some website, to shake the printer. Apparently paper and other objects might collect and get in the way of the carrier. I tried it, and it solved my problem. I do not know how long it will work for, but I was actually able to print something.
I have had the clear carrier jam problem the past 3months, spoke to over ten technicians but no one seems to have been able to resolve it, let alone clearly explain the cause. But just to say buy another printer.
How many Dell 942 printer am I going to buy!!!!!?????
SOURCE:
How do I clear a carriage jam error on a Dell 942 all in one printer?I changed both ink cartridges and the carriage moved and let out a scratching sound and the error msg, clear carriage jam came up on the...
Carriage jam errors usually mean something is blocking the carriage from moving. It's usually a crumpled piece of paper left over from clearing a jam, or a faulty purge unit/capping assembly.
You should check to see if the printhead is locked or movable when you power off the unit. If it will move freely when it should be locked then something is blocking it from moving into the "home" position. If there is no foreign object inside then the capping mechanism in the wiper or purge unit may be broken or jammed. Oft times a good disassembly and bath for the purge unit will get it working again. However, this depends on how technically skilled you are and how much the machine is worth. It would take at least an hour in a shop. If you don't do it yourself and the machine is worth less than $100, it may be time to replace the machine.
Sep 24, 2010 | Dell 942 All-In-One InkJet Printer
Dell all in one 942 ink jet printer reads "clear paper jam" there is no paper stuck. How do I fix?
Try this; Remove the cartridges, disconnect the usb cable, turn off the machine, unplug the power chord and switch off the adaptor from the wall switch, leave the machine for few minutes while you do some cleaning, like cartridges contact points, clean the rear panel door, also open the front panel door and check for any foreign particles, you should remember that even a small/tiny piece of thread or hair can create this problem. Now connect the power chord, switch on the wall switch, and power on the printer without the cartridges installed and the usb cable connected. Use the Power Button the switch on the printer. Leave it Switched On for few minutes and again turn it off, install the cartridges, connect the usb cable and again reboot the unit. Press the power button once and again keep pressing when it starts booting. If the problem still persists, your printer needs service.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Dell 942 All-In-One InkJet Printer
Dellv305 printer, clear carrier jam. My son pulled the paper out from the bottom of printer. How do i clear carrier jam?
Please perform the steps mentioned in the link below:
Paper Jam
The steps would help resolve the carriage problem as well.
Jun 17, 2010 | Dell 926 All-In-One InkJet Printer
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Carrier jam
Hi , check the belt may loose , the tensioner not working or belt not in pulley alignment.
Mar 04, 2008 | Dell 942 All-In-One InkJet Printer
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Carrier Jam
This happens, when printer is old one or it has either dried ink on carrier stall bar or some obstructions. Move the carrier stall manually 3-4 times from left to right and then take a damp cloth and clean the metal bar on which carrier stall moves. If you have kleenex and WD-40 nothing like that. Lubricate the bar, with that or some other lubrication agent. Do it once in a month, if printer is too old and/or u use a refilled cartridge. Dell is great!
Jan 03, 2008 | Dell 942 All-In-One InkJet Printer
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
380 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
