Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Disherwasher not filling all the way
By netto on Sep 09, 2007
My dishwasher doesn't fill up all the way.I think it has something with the float. I have to add at least 2 gallons of water on the wash and rinse cycles
Best Solution
posted on Sep 09, 2007
Helpful)
dovi
Rank: Guru
Rating: 88%, 2495 votes
Check first the filters on the inlet water line (both sides).
Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)).
If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
Check as well for valve's coil resistance. In case you don't have a resistance measurement - you should replace it for a new one.
Let me know if you will need for further assistance.
Good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Apr 23, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
well i just bought 3 of these and thought that something was wrong with them.......well im still working on the problem....even had a tech come out........im a electrician myself.....but im not doing much to a brand new machine.....but this i have found and its a fact.....i plugged my meter into the socket that turns on the valve and it has power for 1 1/2 min only........so if you have a water pressure problem ........it want fill up in time .......now......i think thats ****....cause there should be a water float that will not let the machine start until it says that enough water has been put in........im still looking into this......but this machine has a timer that turns off the water......not a water level switch......
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
Kenwood dishwaher..model KFW243A..machine was put on a cycle but the waste outlet was blocked... (More)
Answer
when i close the dishwasher door and hit the start button, nothing happens. If I push the different... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
