Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Tv problem I have a sony grand wega kf60xbr800 i turn it on then after about 30sec it turns off the standby light flash 34 times and starts the cycle over
  • 81 Answers
Change the lamp
Posted on Oct 12, 2007
SOURCE:
Sony grand wega turns off & o ever 30sec flashes green light
it's a power failure.try to replace the regulator in power supply board.
Sep 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Buzzing/screaching noise when turned on, standby light blinks and then lamp light blinks
It sounds like a bad lamp. Replae the lamp firts, but there is a chance you have a bad lamp driver also.
Oct 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Kf60xbr800 internal lamp component, what is the replacement costs for such parts
Go look at your set up timer in menu see what it says some sets will tell you to replace lamp, while other types of DLPs just start turning off and on ,their may also be something wrong with area around lamp too.Read your service manneul or get one on www.free service manneuls.com . ThankYou for using FixYa.Have a Nice Day.
Feb 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
Turns on then off
check your sleep timer it is on or off
Sep 09, 2007 | Televison & Video
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
198 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
