Question about Linksys Wireless-N WRT150N Router
Connection Not Consistent
I purchased the router yesterday. Hooked it up today. Then Restarted my computer, and now have to do the Whole set up thing again just to get wireless. I have to walk across the house with my laptop, hook up a wire to it from the router, run the set up wizard, get the connection I need, then go back across the house to my room. Now im hoping I dont have to restart the computer again. Everytime I turn off the laptop, I can no longer access the internet.
  • Thephone Rush Sep 11, 2007
    Thanks, That was one of the problems,also the security had been enabled letting one computer in an locking the other out. We turned off the security logged in and then turned it back on, and everything has been good ever since. Thanks.
    Scholar:
  • 47 Answers
You shouldn't have to run the setup wizard to reconnect. It sounds like you just haven't configured it to auto-connect to that wireless connection. Right click on My Network Places and select Properties. Right click on your Wireless LAN connection, and tell it to connect. You should be able to go through those settings and tell it to auto-connect to your router as well.
Posted on Sep 09, 2007
SOURCE:
Cannot connect to internet today. Yesterday all was well.
If the modem works and a desktop pc works through the Ethernet port of the router, then try plugging the pc laptop into the same Ethernet port using the same cable as the desktop. Most laptops have an Ethernet port.
If this works, then the problem is the wireless access?
Check you still have the wireless set-up on the pc laptop, if not re-install it.
Mar 03, 2012 | EnGenius ESR-1221 EXT Router
Trying to go on netflix getting code 51030 says please confirm ssid not sure what that is. purchased new router today..computer is working
the SSID is the name of your wireless network. you may need to set up your wireless connection again since you got a new router. It may be trying to use the old connection, which will not work.
Aug 19, 2011 | Nintendo Wii Console
Have dsl connection, works fine. when linksys wrt54g router is correctly installed, no internet connection! ran diagnostic, all is fine, but no internet connection found-can't seem to upload new firmware...
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Turn the DSL modem on.
Wait for its lamps to settle-down to a consistent pattern.
Turn the Linksys router on.
Turn your computer on.
Wait for it to settle-down.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
You should get output somewhat like: Default Gateway .... 192.168.123.456
if you have a connection between your router and your computer.
If you have that connection, you should be able to upload new firmware from your computer to the router.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
I have had my Veralink router Westell (Model 327W) sice I hooked up with Verizon DSL in 2005. In the past several weeks it keeps dropping my signal to my other computers that i use a wireless adapter to...
hi, try to connect that particular computers directly to the router using the ethernet cable,monior the internet connection,if l the internet connection is consistent, theres a possiblity that you need to update the driver for your wireless adapter,try to uninstall and reinstall it,but if the internet connection is still dropping off,contact verizon and tel them that you are having an intermittent connection to the internet,have them check the dsl line and if possible,ask for a higher tech support to do a test assist for the connection...
thanks and God Bless
Jun 03, 2010 | Westell Wirespeed VersaLink...
Hooked up arris modem with lynksys G series router
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser http://192.168.1.1/ , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Arris Touchstone 450a (CM450) Modem
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I had this set up with a cable company yesterday and when i got today i have not been able to get online with my computer hooked up to lindseys router which i was using for months with the other company...
Hii
Just do a powerrecycle for one minute - e.g trun off router then turn off modem - wait for 1 minute then turn ON modem first wait for lights to get stabled , then turn on your wirless router -- i am t will work for you
Mar 12, 2009 | Linksys (WRT54GC) Router
No network detected to setup wireless router
You have to set a network connection on the computer. Go to the control panel and chose Network, the set a new one.
Jan 06, 2009 | Computers & Internet
Router getting poor connection
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Jun 06, 2008 | Buffalo Technology AirStation G54...
Linksys Wireless-N WRT150N Router Logo
90 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
