Question about D-Link AirPlus Xtreme G DI-624S Wireless Router
DI-624s Hi I cant get my USB hard drive to connect through the router
  • sthnman Sep 10, 2007
    Hey sorry,
    I just bought a Dlink 624s storage router and my 250gig harddrive is not connecting to it... I have some smaller flash drives that are working.
    Can anyone suggest a better Storage Router?
Quiero EL Driver
Posted on May 28, 2008
Fat32 is the answer
Posted on May 26, 2008
    Scholar:
  • 47 Answers
That sucks... we need more info before we can try to help though.
Posted on Sep 09, 2007
  • Anonymous Sep 10, 2007
    I've never purchased a Dlink product that wasn't a pain in the petute to get running. When I look to purchase a product, I surf out tohttp://www.cnet.com and do a review search to see what they say about the products. Remember, you get what you pay for... and tech support is usually the first to be chopped.
6ya staff
SOURCE:
Repetitive disconnect problem....requires powering off & on to reset
I used a D-Link Di 624 for a number of years with Comcast and never had a problem with the router, but I did upgrade the firmware. You may want to look at the following items from D-Link about the DI-624S and see if you can find a better solution. I took the router out of service as I changed to Verizon FIOS and use their provided router.
See: http://www.dlink.com/support/faq/default.aspx?question=DI%20624S&page=1
Dec 06, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
I'm trying to set up 2 computers in a wireless network. I have a D-Link DI-624 router. Where do I plug in the flash drive on the router?
Hi norman66, the wireless flash drive you connect to the computers that do not have a wireless card, not the router. First install the CD on the computer and then insert the usb device.
I hope this helps. Please do not forget to rate and provide positive feedback for our fast free support today. Thank you :D
Apr 30, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link DI-624 AirPlus Xtreme G 2.4GHz Wireless router not connecting using the wireless point on it
The DHCP on your router isn't working properly. You should perform a hard reset on the router by finding the reset button on it. Take a pen or other small pointy object find find a tiny hole on the router. Press and hold this for 20-30 seconds. This will reset to factory settings and the password to the router will also be reset to its normal default.
Reconfigure the router as if you had just bought it new and it should work properly this time
This is from a DI-624 Router, and should be very similar to yours:
Oct 16, 2017 | D-Link AirPlus Xtreme G DI-624S Wireless...
Wep?
If your router has security you have to enter the security key on the laptop for it to connect properly.
Jul 26, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
Need help with connect a d-link,dl 624 router
You wireless router/access point can host several simultaneous connections to the internet. Just connect your laptop to the wireless network as you would from your desktop computer.
Hope this helped.
MO
Jul 11, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
Jun 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can't find printer connected to DI-624s USB port
Have you tried:
(1) add a printer
(2) click Next when the Add a Printer wizard is displayed
(3) select Local printer attached to this computer. Untick automatically detect and install my Plug and Play printer; click Next
(4) select Create a new port - Standard TCP/IP Port. Select your printer driver.
(5) enter IP address of printer: 192.168.0.1; accept default port name; click Next
(6) select Custom, then click Settings
(7) select LPR protocol; enter 'lp1' in LPR settings
(8) click Finish
Hope this helps! :)
Apr 04, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Open Questions:
See all D-Link AirPlus Xtreme G DI-624S Wireless Router Questions
D-Link AirPlus Xtreme G DI-624S Wireless Router Logo
93 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
