Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
No power top drawer
Top drawer has no display, lights or response to button pushing. bottom drawer works fine. top drawer has water in it that gets hot when bottom drawer is used.
  • greggo Sep 09, 2007
    Thanks for your suggestion, but it didn't reset. There is no error code, beeping or any response at all. The only thing that happens is the heater element starts to get hot. I have disconnected the heater element harness from under the drawer for now so that we can use it. Any other ideas?
  • Anonymous Mar 25, 2014
    The top drawer of our dishwasher has stopped using salt. Any idea why? the bottom drawer is OK
    Master:
    Sergeant:
  • 461 Answers
Try to reset your dish washer. Turn off main power supply and leave it for at least 1 min. Is there any error code appear/beeping sound?
Posted on Sep 09, 2007
SOURCE:
Greetings. I have a Fisher & Paykel dishdrawer - the top drawer appears to have lost power mid cycle and the lid has not retracted - no led display - no response from the buttons. The bottom drawer...
Describethe inside of unit,any wear on it anywhere, the rack the dishes go on is it plastic coated? is it wore with rust comeing though on tips here and there?
Mar 07, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
On our double drawer dishwasher, we are getting a code--which illustrates no water--this is for the top drawer, the bottom drawer, works fine--and the water supply is on--please help.
Sorry to read about your problem, I hope this helps you out.
you must have a defective water inlet valve, for the 2nd drawer. or a bad control relay for the valve.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 25, 2010 | Fisher Dishwashers
Power light + bottm drawer closure
the plastic covering at the bottom is clipped in. check outside diameter of the cover and u will find the clips. is your activator board in working order? when u have a leak on these units it sometimes causes problems on that lower board.did u put connecters back properly? check these things and reply back 4 more help if needed. good luck.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water will not drain out of top drawer
To determine if your pump work, before attempting access from the bottom of the top drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water won't drain
To determine if your pump works, before attempting access from the bottom of the top drawer or from the bottom of lower drawer: You can manually pump the water out by doing the following:
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer and or you are running the top and your air gap allows a back flow to the bottom drawer.
Top Drawer light is out-display eratic powers on and off at will.
Below is the service manual link and a web site that I found. refer to the lower section where a person writes in that the fixed the flooding with a hairdryer. I hope this helps, they seem like fantastic dishwashers.
http://www.scribd.com/doc/6462163/DD601V2-Manual
http://fixitnow.com/wp/2004/10/25/appliance-repair-revelation-fisher-paykel-dd602-dishdrawer-f1-code/
Mat
Please rate me
Nov 30, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykell DD601 V2 Top Drawer Overflowing
I suggest pressing the keylock and power button together, hold for 5 secs, the display will change orange, the display should read HP if it says LP, press the start button to make display read HP.Then press power button to store. You will need to manually removed the water from the machine before restarting
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishdraw DS603
look closely at hte display in theright corner is there a little icon that looks like a "lock". if so your control lock is on. do you get any response from any buttons??? if your able to power it up did you try to stop/andrestart unit. sounds like a silly question but sometimes the lid locks down from a power surge/interuption. restarting or canceling current cycle forced drawer to unlock and lock itself..assuming this is the top drawer is the bottom functioning ok??, behind the bottom drawer taped on back wall of inside of unit is atech sheet, with a pretty good troubleshooter. to remove the drawer push in rectangler hinge locks in hte bottom front corner of drawer front, just below the circles(no noeed to remove the circles)push themin and slide back the drawer will lift off and your able to set it aside(wont come out to far its connected by the hoses but itll come out enough(reset the door unto the hinge slides and pull hte lock latch foward to lock back into place
Mar 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
632 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Mark Davis
Level 1 Expert
Bruce Denton
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
